Anyone else have back trouble after hollowing?
Dick Coers
Just got back (pun intended) from the chiropractor after a pretty long hollowing session the previous evening. This is the second time, but in about a 6 month period. Anyway, I guess I'm putting myself in a twist when I do this and am messing up my left shoulder and neck. After the first incident, I made sure I kept my knees bent a little, and tried to stay squared up to the lathe. But this time seems a little worse. Anyone else? Any advice? Do you think it is in the pulling motion, or the way I stand? Do I need to relax more and take a little longer to do the work (not so agressive)? Maybe I should switch to the captured style so I don't twist when I rotate the articulated arm? I have a Oneway 2436 with a home made articulated system. After that first time, I rotated out my lathe and tried to work on the short extension, mounted outboard. The extension wasn't long enough, so moved back inboard. I think I may try to build a mount for the hollowing system off the end of the extension. Thanks for any help.
Re: Anyone else have back trouble after hollowing?
Good posture while turning is a .....
JamieDonaldson
..big issue as you now know. Bending over to work is not comfortable, a good reason that short bed lathes are beneficial, and raising the lathe to eliminate bending is another big help. Another issue is body tension, because "white knuckle turning" is not very enjoyable or productive.
Don at Central Illinois
I don't use a captured system (yet) but I was twisting around and even sitting on the lathe, ala David Ellsworth, but I didn't relieve any tension until I started standing on the 'wrong' side of the lathe for hollow forms. I don't know if that would help on a captured system or not. Maybe worth a try.
Ralph Lindberg
Don has a good point, personally instead I hollow in reverse, that is with the lathe going backwards. I find I don't have to twist as much. Both Don's and my solutions are basically the same, your back is less twisted
Dick Proper exercises to strengthen the core muscles, especially the stomach will work wonders for back problems. I used to have problems (not related to turning) I've always done a lot of working out but started concentrating harder on the abdominals and lateral obliques and most of my problems have gone away.
That's only part of the problem. Learning to relax and stand erect will help a huge amount when hollowing. However I don't hollow enough so by the time I get deep I catch myself hunching over. I can move my headstock on the Powermatic which helps a lot but I still get a little white knuckle when I hollow by hand.
All that being said, I've been a convert to the captured bar systems. When you can stand erect relaxed and hollow with one hand gently moving the cutter it takes all the white knuckle out of it. Then if you add the lazer it even takes a lot of the worry of measuring out of the equation. I don't use it for small hollow forms because it takes a minute to set mine up. I do use it for anything over about 6" deep because it's just so much less stressful.
Lyle Jamieson
Lyle Jamieson
If a captured system is set up correctly, you just stand upright comfortably and watch the laser, and do the hollowing with one hand resting on the tool rest for control. It's a fineness thing not a strength thing. Hollowing does not have to be hard work anymore. It is a hard habit to break, standing hunched over looking in the hole. You can not see anything in there anyway so dont get a stiff neck and sore back...and arm...and shoulder...trying.
Thanks guys, now with Craft Supplies 15% off...
Dick Coers
With Craft Supplies giving 15% off on everything in the store today, I think I will order the Jamieson System this afternoon. I could make one, but since I did well enough at my Christmas Art Show, I need to offset some income.
I'm not hunched over looking in the hole, I do have a laser. I think I am hunched over a bit (that's almost my normal posture as I get older), but I am twisting with the articulated system. I'll try more of a pivoting action using my arms. I'll use my hand as the fulcrum on the tool rest, and push with my other arm. Thanks again!
Bending AND Twisting - A BIG No No
charlie belden
Chiropractors and Orthopedic doctors will tell you to avoid bending AND twisting. When you bend over, you're supporting about half your body weight with your spine and muscles and tendons and ligaments - it's a system. When you twist, you're stretching those muscles, tendons and ligaments even more and torqueing your spinal column. Done suddenly and independently and the system probably will complain. Do either or both for 10 to 20 minutes, repeatedly over and hour or two - and the system will use it's Self Protection mechanism to protect itself from further injury. It's called PAIN. RED leaking or shooting out of us is the body's Warning System - Level 1, PAIN is Level 2. Ignore either one and the body has a system for stopping you. That's called Unconsciousness - designed to take almost all of the physical stresses and strains off the overall system. Call it fainting or passing out - the idea is to get you horizontal - and not moving.
Ellsworth apparently starts each day's class with stretching exercises and reminders of the importance of your stance and posture.
Captured Hollowing Systems and your tool rest control all but two of the six tool motions, leaving you to only control left/right and in/out. No need for you to keep the "handle end" from moving up or down, not white knuckle gripping of the handle to keep it from spinning. And you can stand straight up while hollowing.
No matter what you use to hollow, it's our I Wanna See! that gets us leaning over - to try and see what the tool is doing. Normally, that's a total waste of time - since the cutting edge is inside - and out of sight.
Captured Hollowing System - with a laser guide - that stays where you set it - will save your back - all other things being equal.
At $50 to $75 per visit to a chiropractor or doctor, a captured hollowing system will pay for itself real quick.
Re: Thanks guys, now with Craft Supplies 15% off..
Jack Mincey
I turn on many different lathes that I have set up at two high school shops I teach at and have learned to spread my legs to adjust my height in place of bending over. It helps a great deal. I also find it comfortable to hollow out my larger HF's sitting on an adjustable drafting stool. I do all my hollowing free hand and find that I can pivot on the stool and control what I'm doing very well.
Jack
Chip in Plano
I agree with everything said thus far and have 1 other comment or maybe it is more of a confession of being lazy. Here it is: Cleanup under/around the lathe. I hollow on the left, right and from the end. I find myself working in what side is best. So I'm stepping over tailstocks, piles of shavings, etc. just to get my feet planted firmly. So when I get out my hollowing rig, I sweep up and deal with the clutter I create that I don't put away like I should. This give me as much free range as possible and I'm not standing in a contorted way...anymore.
Good shoes always good for the back, too. I wear Crocs and SAS shoes....but I have plantar facitis, too.
No, But.............
Barry
No, but I sometimes have tennis elbow after a hollowing session.
Sean Troy
Sounds like your lathe is way to low for you. I had to raise my lathe 6" to keep hollowing from bothering my back.
Dick Hines
Dick Hines
I have one of Lyle's rigs and can stand upright and hollow. Of course my PM 3520 is sitting on 4X4s and the leveling legs are all the way out.
I have not had back problems in years.
Get a short-bed or swivel-head lathe
I had really major back problems back in the 90s. When I was in the market for a lathe, I got a Poolewood, which has a swiveling headstock. I can swivel the work out about 45� and stand directly in front of it. They don't make Poolewoods anymore, but there are other lathes out there that let you stand in front of your work, whether by swiveling the head or moving the head down to the tailstock end. If other remedies fail, you might want to consider getting another lathe for certain types of turning. At $50 a pop for an adjustment at the chiropractor, it would pay for itself in a hurry.
Ellis, can you explain that chiropractor pricing
Dinyar Chavda
When you say $50 a pop, do you mean $50 per visit, or $50 for each thing he "pops" back into place?
Re: Ellis, can you explain that chiropractor prici
Dick Coers
If that was priced by the "pop", I would have had a couple hundred just in my neck! Luckily, my insurance covers most of my visits (after deductable). So that last visit cost me $7. I've been much better this week, and hollowed a small vessel this morning. I concentrated on a straight back, and relaxed knees. No pain at all.
I was raised on the farm with livestock, and .....
Dick Coers
learned very early on, to not do what you suggested I might be doing. Cattle on full feed could result in a disaster! :D
"It is a hard habit to break, standing hunched over looking in the hole."
