I was buying cleaning supplies at Lowes to help clean up my Wife's house and found a deal on a refrigerator I couldn't pass up. I did measure the width to make sure it would fit the hole where mine sits. Never thought about the height. I thought they were all the same. It was 1 1/2" taller. I had to rough cut a new hole. I got it all roughed in late last night so now all it needs is Drywall. I'll pick that up after a visit to the Dentist today and hopefully finish it off later today. Thank god for Sawsall. It took about 30 minutes to rip out the old ceiling and cut the studs to make raise the new ceiling. Without one of those I would still be cutting and hacking. Best $20 I ever spent at a yard sale. Besides, it will cut and carve bowls so it's an essential item for the shop.
I've been there and done that, although not to the same 'sawsall' degree as you have; fortunately my modification didn't involve framing or drywall....
My new 'fridge was 3/4" taller than the opening, and fortunately my retrofit involved nothing more than cutting into the bottom section of wall-hung cabinets located above the refrigerator. I was able to cut away enough of the cabinet to make it fit, and even hand-scrolled (using a jig saw) a decorative profile at the ends and center to make it look like it was deliberately made that way. I sanded and finished the cut surfaces, and it now looks like it never was changed.
One thing to keep in mind is the need for adequate ventilation behind the refrigerator - especially in an enclosed installation like yours. You might consider putting-in some ventilation holes (especially above the unit) and buying vent covers to make the openings look pretty, to insure that that there is adequate air flow under the unit, along the back, and out the top somewhere. It will lengthen the life of the fridge if it can release heat as efficiently as possible.
Hey Steve, we have an old car that can now go up on blocks. I'm wondering if I could make a kiln out of that. I realize to properly fit in with the neihborhood it should be filled with beer cans but I don't drink beer so that's a problem.
where a tool should go. Actually I have a new tool that I don't know where I'm going to put it. I was given a 16/32 Perfomax sander. That thing is huge as far as space goes. A friend was getting out of woodworking and this one had a bad platten belt. He offered it and I jumped on it. Boy is it in the way right now. A complete shop redesign is going to be in the works.
In my area there should also be a rubber deer with a target on it in the yard as well as swing made out of a tire and wouldn't hurt to have a chain hoist from one of the limbs for swapping engines.
Then there's also a half dozen fighting roosters and at least 3 dogs on short chains attached to a doghouse with a bare patch worn around it.
Of course if you also don't have a burn barrel and a rusted out pick up truck then you just ain't from around here.
He he, we have a guy in our playgroup who we've nicknamed "Destructo-Boy". He comes in at the start of most every remodeling project with two Sawsalls, 4 packs of blades, and a 3 lb sledge and floor wedge. We just mark what comes out and stand back. Can't drive a nail with a gun, but the guy and his Milwaukees are a 1-man wrecking crew.
You can always tell the rich folks from the poor folks at a glance...there's two (sometimes three!!) cars up on blocks in the yard at the rich folks' houses.
John, I bought a new drop in range years ago and was told it was the standard size. It was for the time. The toruble was the old range was statdard for another time. I ended up cutting the counter top and trimming the cabnits and lost the storage space under the stove.
Lesson learned? NEVER BUY A NEW APPAIANCE WITH OUT PUTTING A TAPE MEASURE TO THE HOLE!!!!!
Standard for Dec 30, 2010 will not be standard for Dec 30, 2011.
