New Shop Design & Layout Help ?
Brad Vietje
Hi Folks,
I've been away from active turning for well over a year now, as our new home has been under construction; the building we are living in will become my new shop space -- aaah -- a heated space, at last!!!
I will be setting up a turning shop, not a furniture-making shop. I will have 3 -4 lathes, (eventually it will be a teaching space), a bandsaw, a ceiling crane for heavy green logs above the big lathe, a sharpening station (probably on wheels), a dust extractor, a finishing room, a drying area or room, wood storage, and a shed area for rough cutting and chain saw work. I will also bring in some "flat work" tools to assist with wood trim and such in the new house (radial arm saw, router table, and such), but these will have to roll away for storage, as I'm not planning on doing much flat work.
I have two questions:
1. Are there good resources on shop layout that are specific to turning? I'm particularly interested in the movement of wood through the turning process from green to rough to drying to finish turning and finishing, as well as using sources of daylight, and other such factors.
2. Has anyone worked on shop design as a club activity? Results? I may try to get the club think tank fired up and approach this as a group activity...
Thanks in advance for your ideas,
Brad Vietje
Newbury, VT
. This takes a lot of thought when you also are trying to avoid putting a window for natural light in the line of fire too.
