Very Spalted Sycamore Bowl
Todd Nebel
This is a 7" simple bowl design. I think you can have too much spalting like in this bowl. It also has a lot of bug holes which I don't care for on my bowls. I think I'll try some of this stock on pens.
Re: Very Spalted Sycamore Bowl
George Guadiane
In my world, so long as the wood is still stable, there is no such thing as too much spalting.
It looks really nice to me.
I don't mind bug holes for "fruit bowls," but holes in salad bowls are not a good idea.
adrien
I suspect that the "bug holes" are from the Ambrosia beetle which caused the lovely spalting....
Fill bug holes with . . .
Doc Green
. . . epoxy and coffee grounds. My procedure is to squeeze out two similar beads of resin and hardener an inch or so long onto a plastic lid for a butter cup or something similar. Mix the epoxy, and then add the coffee grounds until the mixture gives a granular appearance. Then force it into the bug holes.
I use 5-minute epoxy and have to work fast once the coffee grounds are added. I only count on a couple of minutes working time before it gets too stiff to work easily. I daub it on until it's well proud of the surface.
A squirt of denatured alcohol onto the lid and the spatula I use to apply it makes cleanup with a paper towel easy. I use the same lid for a month or more.
After it cures for about 15 minutes or so, it can be carved with a sharp carving tool to remove some of the excess and reduce the sanding required.
Let it sit an hour or so before you begin the sanding. (Power sanding with a drill is best because you can localize the treatment.)
Fresh (unused) coffee grounds give a courser texture than grounds that have been used to make coffee. Of course, you can use sawdust or any number of materials as filler for the epoxy, but most of the time I go with the coffee grounds.
Some folks get fancy and add brass shavings or turquoise to accentuate the holes, but a blue bug hole doesn't appeal to me.
Not everyone cares for this treatment, but it works for me. For smaller imperfections, I use wood filler and "retouch" the repairs with acrylic craft paint, but that's another story. ~Doc
Dick Wilson
For some reason, maybe beause all I have heard is ambrosia maple, I always thought the ambrosia beetle liked maple trees. Then again a tree is a tree and where ever the beetle lands when it is tired, hey.
charlie belden
Great Chip Bowl. You'd never know if you were out of chips - just by looking.
The current AAW magazine American Woodturner (?) has a great article on spalting. Fungi are pretty interesting critters - some are VERY territorial - fine black lines in the spalting are the Front Lines of battles between fungi.
Leo Cuellar
Leo Cuellar
Nice looking piece of wood Todd. So funny, I just turned a 9" one with an almost identical rim/bead detail out of plain maple. I'm not going to post a pic though because it was my first attempt at a lacquer finish. :\ While it came out better than expected, not good enough for here.
Keep on spinnin'
Leo
B. Leathers
It's a thing of beauty..Some of it is reminiscent of old world maps.
