Woodturners Bandsaw Blade?
Keith Inscho
I noticed some time ago that Highland Woodworking sells a bandsaw blade made for cutting blanks from green wood. Is this blade really any better than others for this purpose? Opinions?
Re: Woodturners Bandsaw Blade?
Bill Neddow
Generally, these blades have a wider kerf so they make a wider cut. Regular blades are made for dry wood, while we work with wet wood. With green wood, the wood tends to bind the blade.
Re: Woodturners Bandsaw Blade? *LINK*
George Guadiane
I use Timber Wolf blades from Suffolk Machinery.
I have cut hundreds (thousands?) of blanks with these blades. While any blade can bind, I find these and the a can of Pam to be about as good as I have ever heard of.
The vendor also works hard to make sure you get what you want for the jobs you intend to do. I use 1/2 inch 3TPI blades for my cutting.
Timber Wolf
Ralph Lindberg
I can tell you I've been very happy with mine. They do cut better then a "regular" blade.
Rob Wallace
Rob Wallace
Keith:
I have been very happy with these blades for cutting green blanks of all kinds of woods - at least for the past 6-8 years..... I've tried at least five or six other brands (Lenox, Olson, Timberwolf, and a few other 'generic' blades to compare) and still stick with the Highland woodturner blades. They do quite well on wet (as well as dry) wood, with good tracking, dust clearing, and work really well when cutting with the grain (i.e rounding an end-grain vessel blank). I don't use them for general woodworking and normal dry wood cutting in the shop, since they are a bit coarse (3 tpi). My second bandsaw, housed in my garage (which only does service in woodturing blank preparation), has never seen a different kind of blade; a Highland woodturner's blade has been on this saw as long as I've owned it! If that's an endorsement, there you go (BTW - no association with Highland Woodworking - I've never even been to Atlanta!).
These blades are 3/8" wide (better for cutting tighter curves than a 1/2" blade), have fairly deep gullets, and the teeth have a greater amount of set than 'regular' blades. I actually have put together at least two group orders with Highland for our woodturning club to buy these blades for most of our active club members.
Because I am a cheapskate, I try to get as much mileage out of them as possible - if and when they break I braze them back together, and if needed, I touch-up the teeth with a diamond chainsaw sharpening burr in a Dremel tool.
I suggest you try one and put it through the paces. (Also - If you do any re-sawing of flat stock, Highland's Wood Slicer bandsaw blade is also exceptional, and has garnered many very positive reviews! I reserve mine for these special operations, and have been really pleased with the Wood Slicer performance as well.)
Good luck and cut safely!
Rob Wallace
I'm even cheaper than Rob!
Mike Brazeau
In addition to resharpening 1/2" 3 TPI and re brazing when they break, I also reset with a hand saw set I bought from Lee Valley. For blanks it doesn't matter that it is a rough cut, just a nice wide kerf. Also great for ripping spindle blank from half log sections to store and dry down.
i prefer timberwolf
bob davis
i use 3/8..3tpi AS blades. have used them for 12 years..highland hardwaew quality has not been acceptable for me..
Re: i prefer timberwolf
mmann
I use the exact same blade from Suffolk and agree that the Highland hardware blades are inferior. In fact we tried some Highland blades at our business and the millshop guy hated them.
Jim Sebring
I've been using the Highland blades since I started turning about 5 years ago. I had one that wobbled (front-to-back) that was promptly replaced. The last one ran for 14 months and only broke when my weak tension spring allowed the tension rod to suddenly unscrew. The thickness on these blades is 0.032"; most 3/8 x 3 tpi blades run 0.024-0.025". I'll keep using these.
I guess I cut more irregular blanks or maybe I'm just not as skilled at the bandsaw but I ruined 2 of the (what I consider expensive) Highland Hardware blades and one Suffolk blade pretty quickly when it binds up in the wood. I bent them which makes them useless. I now buy $7 blades from my local saw sharpening service. I get the same 3TPI 1/2 but the back is stiffer apparently because I have never bent one. I have broken 2 over the years but he just welds them back for me. I cut an awful lot of wood with them because when the wood starts to check I cut it up into spindle blanks. I have taken the time to sharpen one just to see how it was done. It works but isn't worth the effort for $7.
