K.I.S.S. - NOT!
charlie belden
Keep It Simple Stupid - K.I.S.S. - is something I initially shoot for - and almost always miss - by a mile or two. But I like to synthesize - to combine things in different ways. The more things there are to combine, the more combinations are possible. So I pick up stuff that I might be able to use for some future project and then forget where I put them.
I got on an LED kick and picked up all sorts of little battrey powered LEDs - rings with flashing LEDs, key chain LEDs, dog collar flashing LEDs, little LED flashlights and RGB LEDs that can be any color you want, clip on LEDs, little rubber balls with LEDs in them. I seemed little battery powered LEDs were everywhere and in everything. I probably have a dozen or more of these things scattered about the place.
About a year ago another wave of Harry Potter struck the neighborhood and the new batch of neighborhood kids wanted Magic Wands. On Halloween I'd promised a fiver year old I'd make her a very special wand - with a glowing tip (LED inside, acrylic rod through a hole down the wand). Seemed simple enough.
Getting the LED inside and out of sight would be easy - they're pretty small. But the availabe buttom battery to make it work was about the size of a quarter - and a battery holder for it added another quarter of an inch, To hide it inside I'd need another 1/8" all the way around it. And because batteries have to be replaced at some point - the Magic Wand would have to come apart in order to get to the battery. The Battery Criteria made K.I.S.S. impossible. Getting everything inside the piece wasn't a big deal. Being able to take it apart to change the battery was the tricky part - made trickier by the need to be able to turn things On and Off - from the outside.
After three or four unsuccessful attempts - I let the project stew and percolate for a while. Almost three months of cogitating, ruminating and procrastinating paid off.
I was rearranging some of my turnings on a shelf above the TV. A little cup I'd turned when I got my first chuck had a bunch of stuff stored in it. One of the stored items was a little anodized aluminum tube strung on a caribener. Twist the top and the other end starts flashing - blue and red. About the diameter of a fat crayon, it was The Answer to my Magic Wand "challenge".
If you wait long enough, and have collected enough STUFF - that you can eventually find - or stumble on - any design obstacle can be overcome.
Example? This.
Still have the drilled bead to turn. And I'm not exactly sure how the parts will be held together - but it looks like the little girl will get her Special Magic Wand for Christmas.
Pays to procrastinate - and hoard stuff ; )
ps. The sun is shining, a few clouds in an otherwise blue sky and it's a balmy 65-70 degrees Christmas Eve Day. It's good to live in Silly Cone Valley!
