I just spent about 45 minutes doing the "needle in a haystack" thing to try to find a small screw and spring from the tool post lock-down lever on the banjo of my Jet 1642 lathe. I am recounting it here to warn others to CHECK YOUR LATHE NOW so the same thing doesn't happen to you!
I was hollowing several closed forms today and as usual, when the chips accumulate on the ways, I scoop-up a handful and pitch them in the trash can as I work. Having been through hollowing 3 vessels already (using John Jordan hollowers in an armbrace handle), I was working on my 4th vessel when I went to adjust the tool rest height, and the lever came off in my hand!! The keeper screw and spring were GONE!
I first did the logical thing and checked all around the floor near the lathe amongst the shavings and accumulated hollowing dust, and even broke-out a spare 13" bar magnet (the kind used for holding tools on a wall) and magnetically "swept" the floor all around the lathe, however I found nothing but a few old wads of steel wool, several handfuls of steel wool "filings", and a razor knife blade. Realizing that I may have scooped-up the screw and spring and tossed it into the trash can with the shavings, I began the exciting task of going through a full 33 gallon trash can of elm, hickory, and box elder shavings......sweeping the top of each layer with the magnet before I removed the shavings, a handful at a time, to another bag....going down an inch or two into the shavings each time. I went through about two thirds of the barrel (approx. 20 gallons) of wood shavings and dust, and miraculously recovered both the screw AND the spring at the same time!
I was fortunate enough this time to be able to replace the screw and spring where they belong, and completed hollowing vessel #4 today! When I replaced the screw, I made sure to put on some Loctite thread locker before tightening that baby down!! I have since checked ALL of the adjustment lock-downs on the banjoes, tool rests, and quills of all three of my lathes (...and found one of the other screws was loose!) and made sure all were snugged tight. I was really lucky and hope to never have this happen again!!
I would like to pass-on this experience and admonish you to CHECK THE SCREWS ON YOUR LATHE LOCK DOWN LEVERS NOW! ! !
Thanks for the tip, Rob. Glad you found them. Exact same thing happened to me with my Jet 1236 -- it's a defect of their banjo. I have gotten into the habit of checking it occasionally, but I like your idea of using Loctite! Gonna do that right away. ...Gary
Another option is to use a hammer to slightly deform the threads. This will keep the threads from vibrating loose. I do this on all of my hollowing tool threads. Works great. Joe Fleming
Turn it down to not include the surroundings, and it couldn't detect a chuck in my hand. Turn it up, and I think it picks up the earth's core. There is nothing in between...
I actually don't have a keeper spring on any of the handles on my lathe (Nova). I did lose the knockout bar once, and never recovered it. learned my lesson well...anything metal has either been painted with a non-wood colored spot or wrapped in blue painters tape.
There is something about the Nova knock out bar that allows it to move to strange hiding places. I spent over an hour one day looking for mine and couldn't find it. Later when I went back in the house there it was hiding next to the coffee pot.
