A follow up to the Saw Stop post
Peter Hyde
I didn't want to hijack that thread so here are some thoughts on riving knives and splitters.
I was introduced to ripping wood on a big old �table saw� about 55 years ago by an elderly sawyer who still had all his digits. The saw had a tall fence that only extended to the centre of the saw blade. No riving knife, no splitter and an overhead guard. I was shown how as the wood goes through the blade, any irregularities in it can cause a wedging action between the blade and the fence. Once the cut passes the back of the blade the fence no longer causes the wedging to happen because it�s clear of the fence, and so no kick back.
Most of the table saw fence systems in use today are primarily for cutting sheet goods so a straight edge against the fence is almost a given, when compared with rough sawn lumber. But plywoods can have tension in the sheet from the manufacturing process which will cause the cut to close on the back of the blade. For a riving knife to work it has to be the exact same thickness as the saw kerf. Too thin it does nothing, too thick and it sets up a wedging action which then means more force applied to push the wood which then sets up a chain reaction that can cause a kickback. So a good prevention procedure is to always use a sacrificial fence that stops at the centre of the blade and allows the wood to be able to move sideways as it�s cut. There is of course a better idea and that's the Unifence which allows the fence to be slid back so there is no fence past the centre.
Working in commercial shops I have seen employees applying all their body weight to a sheet of ply trying to force it through a saw equipped with a long fence and a splitter. Eventually the saw trips out or there's a kickback and a frightened employee. I show them how to install a short fence and problem solved. Saws equipped with power feeds or straight rip attachments can also be a good solution.
Personally I think a bandsaw is a far better weapon of choice for cutting lumber.
