Firewood's Journey - Off The Lathe
charlie belden
After turning away the garnet shellac drips in the inside of the "bowl", resanding and this time refinishing with many coats of thinned clear lacquer applied french polishing, Firewood came off the lathe. In hand it changed from a visual piece to a VERY tactile piece.
We think of our turnings mainly as visual art, in part because of the Look But Don't Touch thing. We bring out the wood's color, growth rings, figure - often enhancing them with stains and dyes and washes of colored pigments. And we present the wood in as visually pleasing a form as we can - that's usually symetrical - about a single axis. Our primary sculpting tool is, after all, a lathe - that lends itself most easily to making things ROUND. All our focus is on the VISUAL impact of the piece.
For additional visual dimensions to pieces, we often carve, texture, scortch and pierce our pieces. But we use these techniques mainly to VISUALLY enhance a piece. And we seldom think of these enhancements in terms of tactility. We focus on The Look, and ignore the more mentally stimulating sense - The Feel of the piece
It's no coincidence that a majority of our brains resources devoted to our senses - are devoted to sight. Oddly, despite all the brainpower it gets, sight is probably the easiest of our senses to trick. Magicians - and artists - do it all the time. That's because our visual system involves a lot of data processing and analyzing and some association - that has to be done - after it receives the raw data - and before - we visually perceive / experience something. And we're starting merely with light - reflected off the surfaces of what we see, or THINK we see.
With vision, we begin with second hand information - the reflected light that gets to our retina. And that image is UPSIDE DOWN. It came through the lense of our eye and that lense flips the image upside down. From that upside down image captured by the retina, the visual information gets preprocessed in the eye, compressed a hundred to one, sent down the optic nerve to a part of the brain that picks up horizontal, vertical and diagonal lines and finds outlines. From there it goes to yet another part of the brain that tries to connect the info it gets with other information already stored - in another part of the brain. Once the incoming info is associated with a previous "known" we finally "see" the piece.
TOUCH, on the other hand, is far more direct - and precise. Our finger tips can detect small differences between two adjacent surfaces - that our eyes can't detect. If you've ever edge glued two boards together yo make a panel for a cabiinet door, you know that your fingertips can detect differences - that are in a few thousandths of an inch, Your eyes may tell you things seem to be flat - but your fingers tell you they ARE or are not. And if you want real precision - use your teeth. Your teeth can feel in the Ten Thousandth Of An Inch, or better, range. Our sense of touch permits sensing things that our sense of sight cannot. If you want to kick up the resolution of touch - close your eyes.
With Firewood off the lathe and in hand, it became a very different, and far more interesting, piece. Eyes closed, fingertips go from a flat smooth surface to a curved smooth surface, to a oddly rippled surface, to a sharp drop off - to another flat not quite smooth surface, with little ripples in it - back to a smooth curved surface and then to a small grooves surface. Depending on how far up the profile your finger travels, it can encounter a minimum of five surfaces - eight if you're at the right height. And then there's the top. The rim is slanted and jagged, but as your fingertip moves towards its center there's a sudden drop of and a completely different surface - a very smooth concavity. Come in from a different direction and the jagged split wood surface gradually becomes smoother and smoother and slides down into the smooth concavity.
A piece like this seems like it would be a nice addition to a Hands On show for the vision impaired - an audience we overlook, but probably shouldn't. We , unlike other sculptors, do piece that are in the Hold It In Your Hands And Explore It scale - perfect for a show intended for, but certainly not limited to, the blind.
If you were to do a piece that would only be experienced only by touch, how would it differ from what you normally turn? Which turner's pieces do you think would be a hit wit the blind? Malcom Tibbett, Graeme Priddle, Terry Scott, Alby Hall, Gary Fisher and John Jordan pieces beg to be explored with hands and fingertips. Suggest any others?
