I just found out that the spindle on my Nova 3000 gets burning hot after I run it continuously for 15 to 20 minutes. I have never touched the spindle when I turned bowls. These few days, I am trying to turn some pens. I do not have a hand wheel so I grab the spindle to turn it. Wow, it is very very hot.
As always, you can also find information such as product manuals, warranty terms and conditions, frequently asked questions etc on our website, www.teknatool.com
It is obvious that the heat is generated by friction. However, I do not observe any wobble or shatter. I ply the spindle with the tool bar and there is no observable movement at all. I only have about 100 hours on this lathe even though the lathe is about 10 years old.
I am going to contact Teknatool tech support to resolve this problem.
Re: Nova 3000 headstock gets really hot, an update
Starry S Chan
I took the belt off and spin the spindle pulley by hand. The spindle doe not spin freely. It will stop after quarter to half turn at the most.
It does look like the bearing went bad. My question is what causes the bearings to fail. Roughing out the exterior of a green bowl blank will generate a lot a stress on the spindle. I only roughed out about two dozen bowls since I started turning in May 2010. In the past, I did forget to release the spindle lock a few times. In one instant, I accidentally engage the spindle lock when the motor has been turned off but it has not fully stopped. I know that the index pin scraped the index wheel at a few places as I can see scrap marks on the index wheel and some aluminum shavings inside the headstock.
In any case, have anyone of you with Nova 3000 lathed replaced the spindle bearings. Is it a easy task? It looks simple on the parts diagram.
Keith Tompkins
Before replacing the bearings, is the machine noisey? Bad bearings make a roaring or whirring sound. Good bearing are nearly silent. Perhaps the bearing preload is too great, in other words, the bearings may be installed so tightly it is generating friction and heat. It may be possible to back off the bearing adjustment.
