Firewood's Journey
charlie belden
I grabbed this piece of what's probably a fruit wood out of a neighbor's wood pile because it had a fair amount of interesting looking heartwood. The ends had chainsaw scars, the sides had that odd texture wood has just below the bark and the face showed the grain torn and jagged where the log had been split in half. Did a little bandsawing - with a dirty band - to trim it so it'd fit in my little JET Mini.
Mounted it between centers so the split face would be the top of the piece, the just under the bark texture on the bottom, and started out to turn an all heartwood bowl profile. Soon saw that if I kept going, I'd end up with a pretty small bowl out of this trapezoidal "blank".
Then the idea for the piece changed. What I had - had obvious evidence of the original log - the textured area below the bark, the split wood surface, the chainsaw marks that cut it to length , the burned ban sawn surface created when it was trimmed to fit the lathe and the basic profile cut by a turning gouge.. I had the evidence of the journey this piece of wood had taken - so far. Turning a smooth hemisphere int the top seemed like a good idea - another step of this piece of wood's journey.
Rubbed on four or five coats of a 1/2 pound cut garnet shellac and when it dried, poured a little 1 pound cut shellac in the bowl , let it skin a little, then put the piece back on the lathe and spun it for a while. And this is what I have - so far.
Think I'll hand around it for a few days and think about if I'll basically stop here - or go back after a small all heartwood bowl. But the idea of a piece that shows clear evidence of its journey is interesting.
Would you clean up the inside of the bowl and stop - or would you go for an all heartwood bowl?
