1.25" x 8 TPI nut
1.25" x 8 TPI nut
1.25" x 8 TPI nut
Starry S Chan
Does anyone know where I can find 1.25" x 8 TPI nuts? Instead of using face plates, I would like to use these nuts to make a few vacuum chucks.
Starry
Re: 1.25" x 8 TPI nut
Walt Bennett
Walt Bennett
Ask Bill Noble - william_b_noble@msn.com
Rob Wallace
Re: 1.25" x 8 TPI nut *LINK*
Rob Wallace
I have purchased them before from MSC. Be sure to get the 1-1/4"x8 tpi and not the more common 7 tpi. Link below.
Rob Wallace
1-1/4" 8 tpi nuts from MSC
Randy Johnson
Why not buy a Beal tap and just make the entire thing out of wood?
I haven�t gone the vacuum route yet but that is the way I make all my jam chucks.
Tap  . . . What Randy said.
Doc Green
Starry, it's not a big deal to make a vacuum chuck out of MDF or plywood, or even solid wood, but you have to have a tap. You can get one from Packard Woodworks, Craft Supplies, or from the Beall Tool Company directly. ~Doc
Bill Howatt
Most of my vacuum chucks are made of a piece of 3/4 MDF drilled and tapped 1.25"x8 with a groove cut into them with a parting tool. In the groove I expoxy a large ABS pipe joiner (bit bigger in dia than the pipe). I true the top edge then glue some closed-cell foam around the edge for a gasket.
When you are using a vacuum chuck you are typically dealing with a dry almost fully-turned, blanced, piece which is very light compared to a wet blank so the above method has more than enough strength.
Bill
Bill McWhirter
My local Fastenal store has them in stock generally.
Well you've gotten all the good answers. I get mine from either MSC or Fastenal. I also have the Beal tap and highly recommend it. The nuts aren't cheap because they are a special type of material and that's whey they have that thread. I use plastic decking material to make my chucks and use the Beal tap to thread them.
dito
JohnKyler
Grainger has them
Gil Jones
Nick Tuzzolino
John: What kind of glue to you use to attach wood to the plastic decking? Is there a name for this decking.? I've seen some around, but not sure they are all the same.
I buy mine at a local salvage/scrap yard. Have to VERY careful to get the 8 thread version rather than the the 7 thread and it is difficult to look at them and tell he difference. I know the people that run the yard and they let me buy a handful, take them home and try them and return and swap the ones that don't work. It would be too much trouble if they weren't local. I need one of those "combs" to measure the threads, but once I got about 20, it was a lifetime supply. I also bought "blind plates" (four inch round disks) and had a local machinist make me about six faceplates.
McMaster Carr
Ron Bauman
Probably various ratings:http://www.mcmaster.com/#hex-nuts/=a8bhd1
Steve Worcester
the machinist part is rather critical. If you weld a washer onto the nut, you you have to make sure it runs true in all directions.
You are correct. The machinist that did mine welded them and then mounted them on a metal lathe and "faced" them off and trued the rim. He did not charge me enough, but he is retired and pretends to make a little money in his shop the same way I do in mine.
Thank you for your replies
Starry S Chan
Thank you for your replies, especially the one from John Lucas. I do not know John but I read a lot of his postings and I am always very impressed by his work. I appreciate that he took time to reply to my posting even in his grieving period.
In any case, I went ahead to order a Beall 1.25x8TPI spindle tap. This is the best solution as it allows me to make both jam chuck and vacuum chuck.
Starry Chan
