Wife's Christmas present
Grant Wilkinson
My first steampunk pen. I hope that she likes it.
Grant Wilkinson
Re: Wife's Christmas present
Jim in River Oaks, Ont.
Hi Grant,
This is a HUGE Wow Pen!! I know full well the hard work it took to create the blank then to have the courage to turn it..... simply wonderful.
I like that you chose the red, it looks great with the metal tones under the surface. It's nice to see new ideas in the pen making world, a 12 o'clock ringer here!!
You have created a wonderful gift, more so you made it for one special person and I know she will love it, now don't let her on the forums!!
Merry Christmas My friend!
Take care,
Jim
Wow is definitely the word. I'd love to hear how you made it. That is just really cool.
Dick Wilson
Grant, If she doesn't like it put it in a small box and mail it to me. I'll even pay for postage :-)))))). Very nice. I don't think I should be expecting a package soon.
Grant Wilkinson
John:
Making them is as much patience as skill, I think. I painted the tubes - red, obviously. Then, I smeared a portion of one tube with 5 minute epoxy and placed the watch parts into the glue. I did as much in one shot as I could within the set time of the glue. Then, I did the same with the other tube. I did them in steps until the tubes were covered. To back up a bit, I had already bent the watch parts to the rough arc of the tubes.
Then, it was just a matter of casting as I've done with other pens. For these, I just used two pieces of ABS pipe stood on end. I plugged the ends of the pen tubes with rubber stoppers, stood them up in the ABS molds and poured in the resin. I use a pressure pot to remove the bubbles, so I stood them in the pot and pressurized at 60 psi. I just leave them over night. That's much longer than necessary, but it does no harm.
The acrylic does not stick to the ABS, so I just cut a slit in the length of the tube to relieve the friction and push them out.
Then, just turn them as any other pen. In this case, though, some of the parts when cast are proud of the bushing line, so I had to turn a slight profile on the body, or risk tearing out the part and the acrylic.
Now that I type it out, it seems awfully darn simple for something that took me so long.
I hope that the length of this didn't make you wish that you hadn't asked.
g
Keith Inscho
Very nice! She will love it.
Wayne Kuhn
Really cool, How many watches were disassembled for this one pen?
Most impressive thing I've seen in a while
steven antonucci
Jennifer Indy.USA
Grant this is really cool. I didn't even know what Steam Punk was until a few months ago. Now I can't get enough of it! I love your pen. Your wife will too I'm sure.
Jen
Grant Wilkinson
I bought the parts, not complete watches, so I don't know how many watches it took to make this.
Fantastic Grant !
Don Orr
OK, I give up- what is "steam punk?"
JamieDonaldson
Or do I need to Google it for an explanation?
Thanks, that's just too cool.
Bob Macgregor
Well, if she ever wants to give you the gears (in writing!), she'll be all set.
BOB
Science fiction with vacuum tubes and gears
steven antonucci
Re: OK, I give up- what is "steam punk?"
Jennifer Indy.USA
Jamie, Googleing would give you a better explanation that I could. Click on images when you google. There's some crazy stuff out there.
Jen
Scott in Falcon
Wow, that's incredible! I'd love to see a tutorial on how this was done!
Grant Wilkinson
Scott:
Not a tutorial, but I can run through the steps. Most are common to any casting. I painted the pen tubes and allowed them to set overnight to be sure that the next steps wouldn't upset the paint. I pre-bent the bigger pieces simply by drilling a hole the size of the tubes into a block of wood, cutting the block through the middle of the hole and using the half-circle and a round rod as a small press. Then, I simply smeared 5 minute epoxy on as much of the tube as I figured I could cover in the open time, and placed the pieces one at a time into the epoxy. When the tubes were covered, I stood them in pieces of ABS pipe, using the pipes as a mold. I use poly resin. I poured it into the molds, placed them into a pressure pot and pressurized to 60lbs. I left them overnight, but the resin gels after 20 minutes or so. This can be done without pressure, but I find the pressure does away with all bubbles. After the blanks were set, I simply turned them as I would any other blanks.
I realize that this is short and sweet, and if you have any questions, I'll do my best to answer them.
Scott in Falcon
Thanks, Grant!
It was the pre-bending the parts in the form that I couldn't wrap my brain around on my own. Now that you explained that part, it all makes sense. Great work!
Scott
