I have a beach hollow form that I am going to turn beads on the outside. I want to burn the bottom of the beads to contrast the blond beach. I have tried several different types of wire from my shop and they didn' work at all. If you use a wire to burn with...... what wire do you recommend? Thanks for your input.
If you can find a piece of OLD (original) formica, the material burns pretty well. I picked up a salesmen's sample with 30/50 samples, so I have a lifetime supply.
Dick, my first thought is that the problem you are having is NOT caused by the type of wire you are using. Instead, I think the problem might be that the RPM is not high enough and/or you are not putting enough pressure on the wire while attempting the burn.
My "burning wire" is soft steel utility wire from a home center, 18 gauge. The wire is about a foot long and is wrapped and fastened around a short stick at each end so I can hold the end and apply considerable force. For a piece 4 inches in diameter, for example, I would have the RPM at least 1500.
I just did a test with a bathroom scale to get an estimate of the force I apply, and it's between 20 and 30 pounds (half that to each end). What I did was to stand a long stick on the scale and then pull (or push) the wire onto the top of the stick with about the same force as I use when burning.
Caution: If you apply this much force to a piece held in the jaws of a chuck, and if the force is applied 8 or 10 inches from the chuck jaws, the possibility exists that you may actually push the piece out of the chuck. So, use the tailstock to help support the piece.
Passing comment: I'm not convinced that a copper wire offers any advantage over a steel wire in this application. In fact, the higher thermal conductivity of copper would tend to conduct heat away from the burning region, AND the smaller strength of copper makes it more likely to break. However, I don't think the heat conduction thing is a significant factor in this case.
Thank you for all the input. I found some old Romex in my hording boxes with solid copper wire. I set it up with handles on both ends. Here goes nothing..........
If you have a printer/publisher in your area see if you can get from them some "stitcher" wire. It's what is used to create the staples in magazines and such. I've used this for years and have only had to replace a piece once so far.
