Have a question? Ask Woody!
Changed my question in a heartbeat (safety brief)
Steven Antonucci
steven antonucci
I have a cheap 5" angle grinder that has served me well over the years, but recently, it has developed a problem. It won't shut off. There is a slider switch that has a mechanical linkage back to where the power comes in, and I pulled it apart a day ago or so. I've been yanking the plug to shut it off.
I have a King Arthur tools chainsaw disc in it now, and the little voice in my head suggested that I needed to take a break, since I've been in the shop for 5 hours... just one more thing before I go in for lunch...
Well.
It is amazing how fast that thing can climb out of a cut and slice the shielding off of it's own powercord. Best part is that it didn't cut any of the copper AND it spiraled around the cord, so nothing is unfixable and nobody (like ME) was hurt.
I decided to wrap it with a bunch of electrical tape and I'll swap out the cord with another one when I can figure out where I put it.
Oh, yeah. I sat down for a bit and wrote this note too... where's my lunch now?
Be safe out there as you try to rush out those last minute presents!
Happy Holidays
Steve
Re: Changed my question in a heartbeat (safety brief)
Guy Bratt
As my brother inlaw used to say.."I knew I shouldn't have done it, but I did. :\
charlie belden
If, for any reason, any cutting tool with teeth - tries to bite off more than it can chew - SOMETHING'S GOT TO GIVE. Either what it's eating has to move - or - the thing with the teeth has to move. If EITHER of those things happens you want to make sure that no part of YOU is in the path of whatever will be moving - at a relatively high rate of speed. Doesn't matter if it's a saw blade, a carving chisel,a spinning router bit, a spinning chunk of wood or a coping saw. If you're in The Path - you get hurt. Could be just a bruise or maybe a small cut - but it could be a severed artery or appendege.
I made jewelry and often cut or pierce cut sheet stock with a jeweler's saw with a blade that had teeth you could barely see - but could FEEL. The idea is to have at LEAST three teeth in contact with the surface being cut to keep the BITE small enough for the saw blade to CHEW. But when you get to the very end of a piece of sheet stock, the metal left to be cut is small enough to fit BETEEN two teeth - a potential Bite Off More Than It Can CHEW - and the cut "hangs". The normal reaction when that happens is MORE POWER. And THAT finishes the cut - and propels the saw - and its sharp teeth - past the end of the cut - and INTO whatever is in its way. If you think a paper cut hurts consider a 60 teeth per inch saw cut with a kerf about the size of a pencil line.
As woodworkers, we play with lots of things that can hurt, mame or kill us. Only if we ENGAGE BRAIN BEFORE OPERATING BODY will we avoid checking out at a ripe old age - with all the parts we came with ; )
You were VERY lucky. I'm glad this was only an injury free Learning Experience. I also appreciate your sharing your OOPS - and hopefully prevent someone else from making the same mistake. As the beat seargent on HIll Street Blues used to say "And hey, be careful out there.".
Put the tool down and step away from the shop!
Dave Belser
Glad you are OK - I bent the 1/2" re-saw bland on my bandsaw this week, it took two tries. The first grab wasn't enough to bend the blade so I did it again. When the blade bent, I realized that it was time to turn everything off and leave the shop.
- Dave
Dave Peebles Lyons, Ohio
Hi Steve,
Glad you are ok. Your story reminded me of one that I witnessed many years ago.
I was working in a body shop. We had a young man that always wore a large oversized flannel shirt that was never tucked in. He was running a large body grinder when his shirt got caught up in the supersonic 36 grit grinding wheel. It had so much torque that it instantly wrapped his shirt up so tightly that he couldn't release the trigger... after what seemed like an hour, maybe a few seconds, he finally just took off running and pulled the plug from the wall outlet. He was pretty shook up, but survived with slight damage and a very red face.
The next day I noticed that we all had out shirts tucked in nice and tight. :)
Best wishes,
Dave
Steven Antonucci
Thankfully, mine wasn't that perilous
steven antonucci
Lyle Jamieson
Re: Thankfully, mine wasn't that perilous
Lyle Jamieson
I do a lot of carving and use the angle grinder a lot. But I would never use one of those chain saw cutting blades on it. It is uncontrollable and erratic. The Arbortech with the small carbide cutters is MUCH, MUCH more controllable. I can hog off just as fast and I can get controlled finish cuts when I want to take a light cut for shaping. I had a student give me one of the chain saw cutters many years ago. He said, "show people this and what it can do". Then he rolled up his sleeve and showed me his scars. It had snapped out of his hands and spun around and took a good sized chunk out of his wrist and forearm.
