New Lathe
New Lathe
New Lathe
John Veerkamp
Got my new 3520B up and running yesterday. Unbelievable how smooth and quiet it is. Now I'm looking to for a way to make it movable without raising the height. I don't have tools for extensive metal working, Pretty much limited to drilling, grinding and bending. Any suggestions?
Thanks
Re: New Lathe
Re: New Lathe
Guy Bratt
I saw a setup where somebody bolted hand cranked trailer tongue levelers to a plank on each end of the monster, 2 on one end 1 on the other. They got them from HF for cheap. when lowerd the machine set on it's own feet. It was in one of the turning mags or AAW site.
Our club uses a hydrolic platform lift under the bed of our 1642 to move it around. Again HF. Works well and can be used as a bench in off times.
Re: New Lathe
Dick Hines
Re: New Lathe
Dick Hines
John, check out www.mustardmonster.com. Lots of info there.
Re: New Lathe
Re: New Lathe *LINK*
Bill Turpin in WNC mountains
Dick: I think that this where you wanted to send him.
monster site
Re: New Lathe
Dick Hines
Re: New Lathe
Dick Hines
You are right Bill. They have changed the page since I was last there.
Re: New Lathe
Here's what I did.
I made 2 removable dolly's. I built them from wood and metal. I needed to move the lathe over gravel to get it in the shop so I used large pneumatic wheels. I lift the lathe with a cheap hydraulic car lift and install the wheels on each end. Then it rolls quite easily.
Re: New Lathe
Re: Here's what I did.
Galen Vetterick
Darn John you just need to add a trailer tongue to that set of wheels and take the lathe on the road with you when you travel.
Re: New Lathe
Funny Story
When I moved from my old place I knew it would be hard to move the lathe. I had to load it on a trailer and roll it across a driveway to get it in the new shop. I built these wheels to solve the problem. My friend who was going to help me load stuff was late getting there.
I had borrowed a friends truck and trailer. I had to back up a slight grade to get to the back door and had a ramp that ran from the shop up to the trailer. I had loaded the washer and dryer by myself. I was pushing the lathe around the shop and thought, hey this thing moves pretty easily. I think I can load the lathe by myself so I pushed it up the ramp. Then it cleared the ramp and started down toward the truck. I have no idea why I thought a 160lb man can hold a 700lb lathe while it rolls down hill on the trailer. It dragged me all the way to the end. I had visions of it bashing my friends very nice truck. Fortunately I was able to keep it slow enough that it just bumped the trailer and stopped. Must have looked pretty funny if you were watching.
Re: New Lathe
John Veerkamp
John,
I like your solution. How do the dollies attach to the lathe? I can't tell from the picture.
Thanks
John
Re: New Lathe
Re: Here's what I did. *LINK*
mike hamilton
John originally shared his dollies about the time I bought my 1642. The cost and timing were both perfect. We swapped a couple emails for details. The lathe is trapped by a small lip on the inside of the lathe's legs. In his case the lip is metal, in mine it is oak. You lower the lathe into a channel and physics and gravity are your friend. The link below is to a set of photos I took as I assembeld mine. Hope they help... and thanks again John Lucas!
Regards,
Mike Hamilton
My John Lucas lathe dollies
Re: New Lathe
detail photo of dolly
I used a piece of steel and bolted it on with long heavy lag screws. It's held so far even with the 300 lbs of gravel on it.
