Delta steel bed lathe inverter
Charles Watson
A friends lathe needs an inverter that is no longer available. It's a Delta steel bed lathe model, 46-745 I believe. If one was available from Delta, it would cost $900-1000.
Any suggestions for him?
Re: Delta steel bed lathe inverter
I would call Baldor. I believe they supplied the motor for this lathe.
I'm sure other inverters would work reasonably well - but I would ask Baldor what the motor requires. You can then see where you can find a suitable inverter.
I've seen inverters go for a lot less.
robo hippy
You might try talking to Brent English at Robust tools. While he sells lathes, he might sell you a converter.
robo hippy
bill Crommett
Beware of after market inverters. I bought a $200 after market inverter for my General 260, and it works but it has no torque at low speeds and does not give a reliable low speed at all. But, I saved $1000.00. Was it worth it? I will know after I pay the year-end taxes and see if there is any money left.
Charles I'm no expert on this but have installed 2 of them. I bought brand name inverters and they were all under $300. The problem is matching the inverter to the motor. I think I got lucky because I didn't know what I was doing.
I would advise asking for advice from the manufacturer of the inverter. They should be able to tell you what will work. Then if your not electronically inclined you can take the inverter and motor to your local motor repair shop and have them set up the programing and to the wiring.
On advantage of installing one yourself is you will have the owners manual and programming guide. That allows you to change the ramp up and electronic braking to better work with your techniques.
Another alternative is to simply start with the local motor repair shop.
I purchased my last one from www.dealerselectric.com
I had another place bookmarked but it must be on my school computer. I'll try to remember to look tomorrow.
Bill Turpin in WNC mountains
The problem with most invertors is that they have about 250 programmable parameters, thoroughly explained in techno speak. Usually about 20 need to be changed. Fail to change a few and you get the above problems. Buy it local from somebody that will help with programming. The increased price is well worth it.
Good Advice
Bill Howatt
John Veerkamp
The invertor I got to replace mine is a Baldor. Catalog # 43801016209, Spec# IN0923E03.
It is 230 volt instead of the original 110 but it works great. Just be sure the dip switches are set correctly. You'll need to modify the wiring for 220 and change out the plug & outlet. Takes about 15 minutes to install and set. The 220 electronic controls are much cheaper than the 110 If you can even find one.
John
Charles Watson
It looks like that part is no longer available as well. I've contacted a local company that sells inverters and they are doing some research based upon the brand of motor, etc.
Based upon his lathe use--8 to 10 inch bowls, the Delta 46-460 midi may be all he needs and cheaper than repairing the older lathe.
Thanks for all the responses.
