Oneway Remote On/Off
MMann
I'd like to add another on/off switch to a Oneway. Rather than purchasing the switch offered by Oneway does anyone know if there appears online instruction for doing this with a hardware store purchased switch? I'm not sure how to wire the switch into the box. Thank you.
Re: Oneway Remote On/Off
Bill Turpin in WNC mountains
Cut one of the two wires going to the stop button. Connect the two cut ends to the new switch (SPST). This is a simple series connection. Duplicating the speed potentiometer is a much harder problem and has been not recommended previously as DANGEROUS!
MMann
Thank you Bill, I assume this in no way interferes with the normal function of the machine's current switch. Both switches will then operate on/off but if either one of them is in the off position then the machine is off?
Does it work?
Bill Howatt
I don't have a Oneway lathe so I apologize if I'm off the mark with this.
The Oneway appears to have a magnetic style switch like most large lathes with a start and stop button. Adding a switch in series with the stop button would stop the lathe but it wouldn't start it.
It seems to me you would need a normally-open momentary pushbutton switch wired in parallel with the existing Oneway Start switch and a normally-closed momentary pushbutton switch wired in series with the Oneway Stop switch.
Bill
Re: Does it work?
MMann
In otherwords buy the remote switch from Oneway and be done with it.
Richard Allen
Richard Allen
The remote on/off for the Oneway lathe attaches to the control box under the headstock mot the existing control.
It is curious that you have a high end lathe that cost a good deal of money. And now to save a few bucks you want to build your own?
You could spend the time it will take to source the parts and put the switch together to make a couple of hollow forms that would more than make up for the cost of the "remote on/off" from Oneway.
Re: Does it work?
I SCREWED UP! Ignore everything I said. My PM3520B works with only a stop button. However the Oneway does us a start button. Buy it from Oneway.
MMann
Thanks...I don't think I said anything about wanting to build my own in order to save the money but thanks for the advice.
