20 Inch Disk Sander Capacitor
Stuart Johnson
After talking to Laguna it is probably the capacitor on my 20" disk sander that needs to be replaced. I took delivery in Oct. 2009 and their stand is no help after one year. While I'm discussing with them about a new capacitor I want to go ahead and line up what I need to do or to purchase one if need be.
Bill Turpin told me to discharge the old one using a 15K ohm resister but I've got a couple other questions.
1. Where or what type of store sells them and what do they cost?
2. After discharging the old one should I just l disconnect the wires at the end with nuts or is there a plug thing on the top of capacitor?
3. The guy at Laguna said to buy one that is equal or greater than (micro ferrets or something I didn't understand). The old one says it is 30MF or HF = - 5% 50/60HZ. I'm trying to get back to them to find out for certain but would the 30 be the number?
Thanks, as you can tell I don't have any idea about what I'm doing but it can't be that hard. I've attached a photo if it is any help.
Re: 20 Inch Disk Sander Capacitor
Bill Turpin in WNC mountains
It is 30 mfd or microfarads. You can go up 10%, but 30 mfd is a very common size. Do not reduce the voltage on the label. It should be 370vac or 440 vac. This is an insulation rating and determines the physical size. It is not the operating voltage of the machine. If the cap is truly bad, it will not need to be discharged. They can be discharged by shorting across the terminals with an insulated screw driver. If still good, there will be an audible pop and arc if shorted out with scdriver.However this will shorten its life if it is not bad. It looks like your cap is round, not oval. It should be a TRUE cylinder, no swelling or distortion. Most caps have .25 inch flat, slip-on, spade terminals, but can have screws. Once discharged, TAKE a close-up digital pic of wiring, then remove. Motor rebuild shops, refrigeration supplies, industrial supplies, WW Grainger, MSC, McMaster, etc should have them. A 15K ohm resistor should only cost a few dollars, available at the same places or RadioShk. A black start cap appears in the back of your first picture. It will be a range of MFD: 100-200, 230-250, 320-378 (ranges are a guess) and a volt rating. All said above applies here also. Have fun, but don't git BIT. Run caps can contain internal or sometimes external resisters. If so, there will be no pop but still maybe good.Bad caps are caused by over-heating, which causes internal steam or pressures which usually causes some distortion.
Stuart Johnson
Thanks Bill. Laguna called back and they gave me a discount price on the cap. I'm getting the gray one, hope it is the correct one. If not I'll head over to Ft. Worth to Graingers with the other one. Neither of them are distorted or leaking as far as I can tell.
Once things are running I'm going to go back to Laguna and let them know what I think about having this problem when there is less than an hour use on the machine.
Nick Tuzzolino
Perhaps this is one of the reasosns they no longer sell this machine.
Stuart Johnson
You might be right. The stopped selling is shortly after I took delivery. Had I known it was going to be discontinued I would not have made the purchase.
Dennis in Southern Oregon
Stuart, have you tried blowing out the motor with compressed air? I have had to do that several times with my radial arm saw. Dust often gets into the centrifugal switch that controls the starting capacitor and holds it open. Unless the motor is a sealed unit, I would try that before replacing the capacitor.
Dennis
Steven Antonucci
Agree with this...
steven antonucci
Usually, when something electrical fails, there is an obvious marker, like blackened phenolic and that burnt circuit board smell. You do need to be careful working with capacitors, since they are designed to hold a charge and can knock you senseless if you mess up.
Back in my days at Stevens, it was common to get some very smart kids to fall for a very funny, but stupid joke. We would be in the electronics lab at the bench and tell these otherwise highly intelligent people that a the very obvious 120V outlet was a capacitor tester, and if the red light went on, that meant the cap was bad... Seems like if you plug these into a 120V outlet, the light always goes on (breaker) and they fly across the room...
Ahh, yes, the good old days...
S
Stuart: hopefully you took all the advice in the previous thread. Have you cleaned and inspected the contacts in the switch? Bad capacitors STAY bad. The are tightly rolled layers of aluminum foil and insulating thin plastic, impregnated with oil (run) or salt solution (start). Once the foil shorts together it stays that way.
The start cap is in series with the start winding. The run is in parallel. It will run with only the run winding, if it has zero load or enough coasting speed from previous run. There is only half of the windings when the start cap or switch is bad. Start with these first since it will run if turning fast enough.
I suggest that you take the whole machine to a motor shop. The further damage that you cause by experimenting will pay for the repair bill in motor life. REMEMBER: when you let all the smoke out, it ain't no good, no more!
Stuart Johnson
At almost 450 that isn't an option. I'll take a look and see what it will take to remove the motor. I can probably handle it.
Wayne Allen (Carson City, NV)
Stuart -- Several years ago I bought the 20" disc sander from Harbor Freight. After using it for a few times, the capacitor started smoking and burned out. I removed it and took it to a motor electric shop where they had a replacement capacitor in stock, and for about $15.00 and 20 minutes of removal/replacement time, it was fixed and has worked flawlessly since. From what you described, it sounds like the same thing. -- Wayne
Stuart Johnson
Thanks Wayne. I have a new capacitor coming from Laguna I just don't know if it is the right one. There hasn't been any smoke, leaking or distortion from either of them so who knows. I'll replace the one I have coming and if that doesn't do the trick I'll find a motor repair shop and take it in.
By the way for those that have suggested blowing out the motor. I went out today and moved the machine so I could get to the back and blew it out the best I could without taking the back cover off. No joy.
Stephen Mushinski
Stuart,
The suggestion was more to cleaning out the centrifugal switch which is under the housing at the connection end. If it is not the start cap then I would bet dollars to donuts that it is the contacts of the switch. Very unlikely that the motor is no good, but stranger things have happened.
As for Laguna, not much of a fan after my friends bandsaw caught fire and everything melted. The spark was created at the guides and sat in the saw dust that was in the bottom of the saw. It ignited later that night with a fair bit of damage to the shop not just the saw. They were no help what so ever.
I just replaced all the wiring and the start contactor for him last week. Also used a metal box instead of the plastic one. Very expensive to repair and the labor for the electrician ( me ) was free. If he had to buy everything new and get it installed he would have been upwards of $600 - $800. He is still looking for a fan blade for the motor which we didn't notice was melted until we got everything up and running. Now he should have cleaned all the saw dust around the saw and on the floor. But really most of us have shavings and sawdust in our shops and clean up only once it get bad.
I only wish I was as disciplined as Clay Foster who has a shop you could eat off the floor.
Stuart Johnson
I can give that a try while I'm waiting for the capacitor. The folks at Laguna were very friendly and interested in trying to help fix the problem right up to when there might be any cost. Then it became my problem.
Update: Took the back cover off to get to the inside and all it covered was the fan blades. The motor itself is sealed. I'm back to waiting.
