Burning Tip for signature
Keith Inscho
I have been using a Burnmaster with a writing tip to sign my work, but I have never really been satisfied with the results. Are there other tips that are better for this purpose or am I just missing something?
Keith Inscho
Re: Burning Tip for signature
Terry Scott
I use the razer tip .8mm ball
Walt Bennett
I modify a Colewood micro tip slightly. Originally it looks like a tiny skew, but I shape it to look more like a knife blade. When writing, I turn it upside down and use the tip most of the time, although the knife blade part comes in handy making straight lines. People who burn things for art would have a fit about how hot I run it, but I'm trying to not go into the wood, so the grain won't deflect the tip. If I never push the tool, my signature, bowl number, date and species come out looking very much like my writing.
Emmett Manley, Lakeland, TN
I use the Pigma Micron pens with archival black ink. These pens are available at Hobby Lobby, some Wal Marts, etc. for about $3, and are supplied in several pen point widths. Much quicker, better, and easier than using any wood burning system. Inscribe on sanded but unfinished wood and the writing is permanent and non-smearing.
Keith I go back and forth between a writing tip and small ball tip. I find the key is just practice which I don't do enough of. All the different woods take a different "feel" for how fast to move the tool and how much pressure to apply. If I can I will cut off a scrap of that wood and practice some lines before going to the final piece. I'm still not satisfied with my writing but it's getting better.
Rob Wallace
Keith:
I'm with Emmett - I also use the Pigma Micro pens with archival, permanent black ink (the 0.45 mm is my favorite) - I get mine at Hobby Lobby, often with the biweekly 40% discount coupon (yes, I'm cheap!). I tried several different woodburning tips, and never liked how the signature and other information looked (a bit too 'crafty-looking' for me - somewhat too close to appearing like a wood "brand" which I don't like for turned items). I also write on wood that has not been finished (although most often sealed with shellac and sanded to at least 600), and then apply a spray lacquer over the writing - it does not run if the ink is thoroughly dry. I think the pen writing looks a bit more 'professional' than a woodburner-made signature - my opinion only.
Rob Wallace
Another vote for...
Steve Kubien
...using an actual pen. I use the Staedler 0.5mm which you can get at any office supply place. Be sure to use it before you put on any finish. Cheap, easy, great results and no set-up.
pigma works well for me
bob davis
burning will not let you change something later
Jennifer Indy.USA
Keith, I've been using a Dremel engraver to sign my work for years. I bought a "handwriting" tip but it never worked well. Woods like ash and elm and oaks are all a pain because of the open grain. So I gave up and turned that pen into a texturing pen. The Dremel, with some practice, gives me a smooth signature in cursive that I'm looking for. It's great for some of the really small pieces I make. With a pair of magnifiers I can get my full name on a 3/8" foot of a tiny hollow vessel. It's my first choice for signing.
Jen
Jim Barbour
Keith I use a Koh-I-Noor Rapido Sketch, .5 tip with india ink on sanded unfinished wood. It stands up to whatever finish I am using and also to buffing. Available at Michaels, Hobby Lobby and any art supply store.
~ jim
Pigma archival pen; BLO & turps finish
Opelika Edro
Chronic lurker here, and way behind the curve with respect to those who post regularly. (Perhaps a couple of new year's resolutions are in order for me.) Based on the recommendations here, I got the Pigma archival pen yesterday -- I have a bradford pear bowl to sign before gifting to my mother-in-law for early Christmas today. I will have to write on the finish itself this time. Since nobody will try to remove the signing or finish, I'm guessing this (signing on the finish, not the wood) won't be a problem -- anyone have comments there?
The finish is 50/50 boiled linseed oil and turpentine -- several coats over probably a two-week span -- which I tried after seeing incidental water spotting and other moisture issues with some pieces I buffed up and carnauba waxed. I thought that finish was attractive, though sometimes a bit shiny -- the incidental moisture problem was what made me try something else. This BLO/turps finish is an understated satin as long I don't build it too much, and admittedly far from perfect. It takes a while to cure, is stinky, and makes me a bit paranoid wrt rag drying and disposal. But, it's forgiving on application, more durable than the wax, and attractive in at least some applications I've tried. I reckon I need to try some poly with it -- have seen others who use BLO/turps/poly, if I remember right.
Oh, yes -- now I remember why I got off on that tangent -- I was using fine-line Sharpie before, and it smeared when I got careless in applying the BLO/turps. I'm thinking / hoping that won't happen with the Pigma pen, based on what I've read here -- but I haven't tried it yet. Any experience?
Thanks, and I'll try not to be such a lurker. Need to work on my turning and photo-taking both.
Re: Pigma archival pen; BLO & turps finish
I don't believe you will be pleased with the results. My experience has been that the ink must be applied directly to unfinished wood. Otherwise, the dried ink will simply wipe off of the finished wood.
Based upon the finish you have employed, I don't know whether it would be possible to lightly sand a small area, inscribe that area with the archival ink, then apply a finish to that area. I think that would be worth a try.
Opelika Edro
Well, nuts. I'm out of town and completely without supplies -- I may have to try to run down a Sharpie and just do it that way again for this bowl. I hadn't thought about the pen wiping off the finish -- not sure exactly what I *was* thinking.
The Pigma Micron pen will serve as well, or better, than a Sharpie. It is not the type of ink or ink delivery system, rather the fact that you plan to place the ink on a now very smooth hard surface -- there is nothing for the ink to penetrate.
An emergency fix might be a sheet of 180-220 sandpaper, then, after sanding and inscribing, spray the area with Krylon Triple Thick Clear Glaze, which dries in 30 minutes or so.
Opelika Edro
Emmett, thanks for the discussion and the emergency fix -- you have taught me several things in these posts. I'm up the well-known creek for today, but this solution sounds excellent for later. Since the bowl is for my mother-in-law, I will see her (and thus the bowl) enough that I can make it right. Thank you again.
