finally, after a few years of searching, I have a largish compressed gas tank. This one was at the transfer station and they said I could take it. It held nitrogen according to the label.
I want to make a long bell out of it. This is a project that's been in my brain for ages. I know I need to cut off the bottom and before I can do that, I need to remove the valve and be 100% sure any gas is out of there. To remove the valve, it should be a simple matter of unscrewing it after bleeding the tank.
Can you think of anything I am missing here that is going to cause me intense bodily harm?
I'd fill it with water and let it stand a day, just to be sure, then cut it with a saw, rather than a torch. You should be OK, but if you blow up, or accidently launch it onto the neighbors roof....
If it was truly filled with nitrogen, you'll be just fine. However if someone filled it with something less benign like propane, you need to be sure that there is no residue. Bleeding it, removing the valve and filling with water would render it safe for your bell. No real need to let it set, the water will expel any gas as it fills up. Keep it upright to fill.
A number of years ago, while on vacation in Colorado, I ran across a very large wind chime (in Rangely?)made of gas cylinders. I don't know how well it worked as a wind chime (I think the structure was a statement about how windy it was there), but it was impressive visually.
As said by others, if it had nitrogen in it, its inert and will be harmless once the pressure is off. I used to use nitrogen tanks to power nails guns on construction sites. (Since heavily frowned upon or outlawed) the tanks started with about 2200 pounds of pressure, yes, really two thousand plus pounds of pressure, so it could get exciting if you cut into a fully pressured tank.
I have seen one of these tanks cut off and set up as a gong. (Japanese Style?) It was hanging from a large cross beam and there was also a beam hanging horizontally from two chains. You could swing the beam and strike the tank. Everything was massive including the sound.
We had a guy deliver oxygen tanks to my high school shop. Someone complained that we had a terrible time removing the protective cap. Standing up on the back of the truck the guy said, Oh these are easy, and spun one off. He lost control of the tank and it fell off with the valve striking the anvil and shearing the valve off the tank. The tank shot right through a 12" thick concrete block wall and landed about two blocks away. It went through that wall as if it were paper. Be sure yours is empty.
Love your line, "it could get exciting"!!! Ya, fully pressurized would not be cool. I'll be making sure it is fully bled out before going to work on it.
Yup, gong-like sound is what I am after. What I'm going to try is to suspend a hammer (wooden ball or disk) inside which will have a wooden paddle of sorts hanging loose in the wind. Basically, I'd like it to act as a giant wind-chime.
Have I mentioned that I haven't discussed this with SWMBO yet? Hehehe, this is going to be fun.
I have cut a few tanks before. If it is aluminum, I used a low hook triple chip carbide blade on my circular saw. I used an abrasive blade for the steel ones.
To mark the line around a cylinder, I like to wrap something like a poster board around, until the edge lines up where they overlap, then mark it with a felt tip pin. They do have a nice ring.
A few years ago there was a big fire in Dallas at a tank firm. I don't know if they were oxygen or some other gas but they were shooting all over the place and landing a good block away.
A friend of mine who did very nice custom furniture and excellent joinery made gongs of these cut-off tanks and constructed supports remiscent of the one pictured here, though not nearly as large nor as ornate. They sold well where ever group meditation was practiced and at 3 to 5 grand a pop!
A few years ago there was a firm that I was doing business with that had an old 6 story building that was built using posts and beams. It contained many large heart pine beams, steel and whatever else that was needed to hold up the large amount of heavy equipment it contained.
The firm that owned the old wooden building finally built a new modern plant about 100 yards away. Once it was in operation they sold the 6 story wooden building for salvage to a company that wanted the heart pine timbers for reprocessing. In turn the salvage company hired some steelworkers to remove the steelwork. Apparently they used an acetylene torch to cut some of the steel and unbeknownst to anyone the hot slag must have fallen into a pile of sawdust/woodchips/debris inside the building.
It must have smoldered for several hours and in the middle of the night finally came to life and set this huge building filled with 100 year old heart pine timbers and planking on fire. The little town in which the firm was located did not have sufficient water to put out the fire so it burned for days.
During the initial stage of the fire the large acetylene tank used by the steelworkers exploded and literally rocketed out of the flaming building. In what direction did it go, well, of course toward the new building and flew through the side wall of the second floor destroying a $350K piece of machinery.
The fire was so hot from the old building that aluminum soffitting on the new building that was a football field away melted.....
The moral of the story is never underestimate the power of compressed flammable gases....
The water will work fine in this case. A few years past I was working with some 350 gallon propane tanks and needed to cut holes in them for a garden irrigation system. I turned to my Brother in law, an art professor who works with metal, and has done such things in the past. When water is not a good option (like this) he makes sure the tank is as empty as he can get it and then hooks up a line from the exhaust of a vehicle to the tank, with a small bleed-off outlet. When the tank is filled with exhaust, he cuts. No oxygen in the tank, no boom.
Sixty some years later he is still here so I guess it works. I just had the guys from whom I got the tanks (propane supply company) prepare them for cutting before they delivered the rather than go to all the trouble and uncertainty. I cut with a torch and it worked like a charm.
