I've been using Velvit Oil BUT....
Rich Pearson in Mill Creek, WA
ran into a problem today. I followed instructions as per the can, used very thin coats with 24 hours drying time between coats. I put on three coats then had to lay off for a while due to hand surgery.
Today, 11 days after the last coat, I chucked it up on my vacuum chuck to finish off the foot of the bowl (photos in a couple of days ) and the vacuum chuck sucked the oil finish out of the wood (walnut and maple) and left beads of oil on the bottom of the bowl.
Is this normal? I do not have the luxury of a spray booth or even a spray area as my basement shop is in my condo and fumes do travel to the neighbors unit.
I like being able to wipe on thin coats but need a faster drying finish.
What faster curing finish do you use?
Re: I've been using Velvit Oil BUT....
I use Minwax wipe on Poly during the winter months when I can't spray lacquer. I tried Watco finishes and they are nice but I never got through a can of it without it going bad. It's too expensive to throw away. The minwax starts thickening toward the bottom of the can but I find you can thin it with mineral spirits and get more use out of it.
Barbara Gill
Rich, I have been using Velvit Oil for over 13 years and have never had that happen. I also have never needed that many coats either. The most important coat is the first as that is the one that penetrates. You don't mention wiping the oil off; that is very important.
If the wood absorbs a lot of oil on the first application then it is wise to allow extra drying time before additional applications.
Bill Youngblood
I just did my first piece with Velvet oil and I love it. I put on the first coat, let it sit for about 15 minutes, wipe it off and let sit for 24 hours. Apply a second coat in the same way. After thoroughly dry, about 24 hours, I polished it with a Beall white diamond wheel and then buffed with the wax wheel without wax. Buff only. It left a smooth satin sheen.
