Black Walnut Amphora (in progress)
charlie belden
An arborist friend who has cut AND DELIVERED black walnut logettes - specifically cut 4" longer than the logette's diameter - that were 3/4s nice heartwood will be getting this "suspended" black walnut amphora. H also gave me a 12"x13"X17" block of all heart wood black walnut that he's been kicking around his place for at least four years.
I like doing lidded boxes and the article on "suspended vessels" in the latest American Woodturner issue inspired this suspended amphora "lidded box".
The turning was relatively straight foreward. The cutting away the "ring" for the supporting legs was not - straight foreward - or as easy as Mr. Scobie's article implied. In part, that was because the lid thing complicated matters a bit.
Took most of the "ring" waste down with a small bit in my foredom. With the lid mounted in a chuck and the "box" held to it with an "O ring" cup center I made forthe tail center, I used a flat "micro plane" "file" to take down the ring waste "close" - then sanded and sanded and sanded to blend it into the amphora "box" AND lid.
Will be using 3/8" diameter "bar pulls" - with one attachment point cut off - for the legs. The method I have in mind for attaching what's left of the pulls to the piece is going to be tricky - but quicker though not easier that the first idea I had for them.
Will post the finished piece - if and when it gets finished.
Apologies for the SHINY - I wetted the walnut with alcohol for the picture - done using a flash.
The attachment "fingers" will get refined after the legs are attached.
Comments, questions & contstructive criticism welcomed.
