ADVERTISE HERE - FREE TRIAL
O.T. Computer Router Questions
Stuart Johnson
We have DSL with a Netgear wireless router/modem. One of the computers is about 60 feet away through a couple rooms. The signal varies from good to poor with the resulting slow internet connection. At time it is next to worthless other times it clicks right along. Right now we have two p.c.'s and two Roku netflix receivers using the wireless. I don't think we would ever have more than any two going at one time.
1. Why would there be a signal fluctuation that is not apparent on the other p.c.?
2. Can the same router be used for a wired connection and wireless?
I could run a wire.
3. Can a second router be used on the same DSL line?
Would probably be easier than running a wire.
4. Is there anyway to boost or relay the wireless signal?
All I've seen on Youtube is some tinfoil stuff.
5. Would changing any of the wireless stuff in the p.c. make any difference?
Something like a new card.
6. Any other suggestions?
Re: O.T. Computer Router Questions
Don at Central Illinois
Not to hijack your thread but why does my wireless router automatically pick up the router for across the street before it picks up mine, in the house?
Steve Worcester
>>Even with the PCs side by side there can be based on the routers software, the brand of chip and drivers used in each PC. Wireless is also affected by a lot of other wireless items, like microwaves, cordless phones and burglar alarms, depending on which type of wireless you are using. 802.11 B/G are the most prevalent (what is the make and brand of your router?), but there are also the A and N.
2. Can the same router be used for a wired connection and wireless? I could run a wire.
>If the router has an antenna and multiple ports for an Ethernet cable, then it is a "wireless router". A cable to individual devices will be faster than a wireless signal and way more reliable.
3. Can a second router be used on the same DSL line? Would probably be easier than running a wire.
>Yes, but don't do it, it is a pain and probably unneeded
>Yes, get a signal booster, usually is a larger antenna, and can have power.
Like this http://www.newegg.com/Product/Product.aspx?Item=N82E16833127063
If all the devices that use wireless are in the same area, you can make one out of a pringles can, but it would be purely directional.
>Other than updating drivers on the operating system, or maybe the firmware for the router, it is doubtful. If you are going to stream high definition movies, I would go the wired route. Yes, you can stream over wireless, but wired will give you more bandwidth and signal reliability.
>If your router has wired ports, turn off the wireless on one computer, plug in the wired and go to http://www.dslreports.com/speedtest and run a speed test. Then unplug the cable and turn on the wireless for that computer. The wired , with nothing else running is as close as you will get to the full speed of your stated DSL package. Wireless is susceptible to too many environmental factors, but a lot easier to work because there is no cables to run.
Steve Worcester
you can usually go into the wireless network list somewhere and move them up or down in priority.
Gee, I thought this about CNC machines?
Dick Coers
Bill Stehman
Stuart, I fought router problems since they first came out and got sick and tired of rebooting them when they begin to fail.
I shoot wireless 200' out to my shop so the slightest variance gave me poor service. After five routers I solved my problem with an Apple Airport Extreme Base Station. Not cheap but designed to handle 50 devices and it has never hiccupped and is the easiest to set up.
DSL speed
Jeff Willaford
Did you mention the speed of your DSL connection? Two PCs typically would not be a problem but downloading/streaming video to netflix receivers can eat up a lot of bandwidth. If that's the case there's not much you can do locally other than upgrade your DSL service (if available).
Dinyar Chavda
Steve's suggestions are excellent. I also sent you an e-mail with an attachment.
Bill Howatt
The router specified in the link is an 802.11 b/g antenna which is not suitable for a 802.11 /n router, should he have one, which uses a different frequency band. So make sure the antenna matches the router.
While /n has a theoretical higher speed and further range, it often has less range if walls are in the path because of the different frequency.
Bill
Steve Worcester
(something i can claim to be a somewhat expert on I guess).
DSL is notoriously slow, and is based primarily on how far you are from the switch/carrier/etc. Speeds are generally peak speeds.
Would help to know what router you have, and I would run wires and drops (my house has a 24 port Gb switch and a 20MB download/10 MB upload package from Verizon, but I also have about 1/2 dozen computers just for me). I only use wireless in my attached garage and for visitors, iPads and such. It is convenient, but it has some drawbacks for those of us who are impatient.
Re: DSL speed
Dinyar Chavda
Following up on Jeff's comment, I had DSL for a long time, and service was pretty lousy, because I was at the extreme limit of the distance from the DSL box(?) that I was connected to. I switched to FiOS (the slowest version), and the difference was truly amazing. Plus, with the deal that Verizon was offering, and the fact that I was able to get rid of the 2nd line that I had dedicated to DSL, I actually saved money. If FiOS is available in your area, you may want to check into the pricing.
Stuart Johnson
My download speed runs about 5 mpbs and upload .60 mgps. Earlier today the second pc wouldn't load any web pages or email using FireFox and Thundebird. Later I got the same download speeds on both p.c.'s. About an hour later the second gets nothing with no changes. The laptop sitting side by side had the same issues so don't thing it is the p.c..
When I tired the same location with a laptop and there wasn't any change. The router is a Netgear N150 Wireless Modem/Router DGN1000. We have gone months with nothing but an occasional problem. Right now I just tried
Speedtest.net and got 41 ping and then nothing. I can't get the speed test to loadl
Steve Worcester
it is an 802.11B/G router with 4 wired ports. If you can't get the page to load, refresh the browser.
Re: O.T. Computer Router Questions *LINK*
Stuart Johnson
Thanks to everyone for your help. I was able to find a firmware update for the router and installed it last night. Right now I'm able to download at 5.06 Mbps and upload at .67Mbps. I also moved the antenna on the desktop so I don't know just what made the difference. The thing is these are the same speeds I had been getting up to a day or two ago prior to changing anything.
One last question. Do antennas like the one listed here actually work? I tried to follow the discussions on the link Juergen sent but it was a case of understanding each word but not the whole so a purchased unit might be best for me.
Better WiFi Range
Enough to make me give up drinking
Stuart Johnson
For most of the day I have from time to time run Speedtest.net and had good results. About 3:00 p.m. all of a sudden zip. No web page would open and Thunderbird sat on opening connection but not showing anything received. I went into devise manager and it said there was a good connection. About an hour later I'm thinking "okay, bite the bullet and call Geek Squad or run a wire connection. All of a sudden with no action on my part other than checking Speedtest I started downloading at 5.09 Mbps. If all works as usual it will crap out again tonight when my wife wants to check her email.
