A55 Smoothing Plane
Got 'er done...
Got 'er done...
Got 'er done...
Tony - Memphis
Thanks for all the help. It ain't just perfect, but I got it hacked out. Of course, the color is virgin cherry, but it will age nicely. The finish is too shiny for my liking, but that's how it came out. I tried the new General Finishes water based (enduro var or something ike that). I wanted something that dried quick - and it did - very quick. I used satin, but after I finished sanding and applying wax, it was pretty glossy. Oh well. After it is handled and used, maybe it will not be so shiny. The top diameter is about 6". That was the widest stock I had. The plan called for 8". They called this a compote.
Now I am working on a pepper mill. First thing I have learned is that it is hard to drill a perfect hole on the lathe. I'm using what I thought was a good practice on my mini lathe, but the bit wandered some and the hole is bigger than the bit now. I had already made a mating top and it is a bit loose now. I must say though that the forstner bits from Lee Valley cut through this gonalco alves (spell?) like butter! I think I can salvage what I have. May add some o-rings to take up the slop (less than a sixteenth). Oh, you can see the top blank to the right of the piece there. You can also see the first base I made and where I cut through the face plate holes - at least I was just cutting air and not screws - missed it by that much! And behind that is another blank I made. I may finish that one later for me or for another gift. This one is for my folks. It has to go in the mail this week. I'll be glad to get back to some flat work after this.
Tony
Re: Got 'er done...
Re: Got 'er done...
Fred Holder
Well Tony,
I can only say, welcome to the world of Woodturning. That is a nice looking piece. Glad you were able to finish it.
Re: Got 'er done...
Re: Got 'er done...
Nice Work!
Hey Tony,
I'd agree, the compote might look a little nicer with a little less shine, but it still looks real nice.
Now, I must admit, I'm a bit confused by one line at the end....(I'll be glad to get back to some flat work after this.) What could you mean by this? :~)
Safe spinning,
Brad Vietje
Newbury, VT
Re: Got 'er done...
Re: Got 'er done...
Tony - Memphis
I build furniture. I'm not a turner! The only things I have turned before are furniture parts and I'm not any good at that either. This is may last project...
You can see the Jet mini over on the left.
Tony
