waterlox curing question
Mark Wollschlager
I am in the process of making a last minute secret santa ( for work ) present.
It is a myrtle bowl with waterlox original as the finish.
I usually do 4 or 5 thin wipe on coats, sanding with very fine grit between coats.
I generally allow at least 24 hours between coats at room temp.
I also allow for a generous post finish application 'degassing' period.
In this case it will be 3 wipe on coats with the piece at an elevated temp.
Between 80-90 degrees ( ambient temp in my shop is 55 today ).
I have been applying the finish and leaving it unheated for an hour or so before elevating the temp.
The question is, could I crank the temp up a bit higher ( 100-110 ) without damaging the finish.
It is a somewhat desperate attempt to drive off the solvent odor for a Monday delivery.
Thanks,
mark
