20 Inch Disk Sander Problem
Stuart Johnson
I have a 220 single phase Laguna 20" disk sander with very low usage that has started acting up. Prior to going to Laguna I would like to have some idea about what might be wrong.
When I used it yesterday it fired up just fine and came right up to speed. Today the disk started spinning slowly and the motor sounded very labored and vibrated. After 15 or so seconds it tripped the (thermal ?) fuse. I reset the fuse and tried again. This time it took a bit longer to trip. I keep resetting and each time it took a bit longer and the disk spun faster. Finally it kept going and worked just fine, coming up to full speed and reasonably vibration free. I was able to turn it off and back on with no problem. Once it slowed down it would start tripping the fuse again if I tried to start it. The motor seems to run very hot but I don't know if that is normal or not.
It seems like whenever there is a similar problem it turns out to be a problem with the capacitor. I opened up the back and it has a round capacitor and another thing that is sort of oblong. Nothing was leaking.
Laguna doesn't have the best rep when it comes to customer service so I would like to have some ideas on the what might be causing the problem before I fall for the "reformat your hard drive" solution.
Re: 20 Inch Disk Sander Problem
Keith Tompkins
Keith Tompkins
Hey Stuart, Did you lose one leg of the 220v. supply?
Stuart Johnson
No, I checked the line voltage and all is well.
dennis ford
The problem is certainly either the starting switch or the starting capacitor (it sounds like you have both a starting capacitor and a running capacitor). If cleaning the contacts of the starting switch does not work, then it must be the capacitor. The starting switch is inside the motor (a centrifugal mechanism opens the switch when the motor gets up to speed) and the contacts may be pitted or dirty.
Bill Turpin in WNC mountains
Check the brown wax plug that is between the terminals of the start cap. If it is cracked, missing or there is evidence of dried salt solution. It is bad. The run cap is oval, but should not be swelled. The sides are straight. Either cap problem is a sign of over-heating which creates pressure in the fluids contained. Over-heating is caused by switch problems. BE CAREFUL, caps , if still good, carry a nasty electrical charge! They should be bled down with a 15K ohm resister, available at Radio Shack. Start caps are in series with start winding. The st winding is energized for only a fraction of a second. If switch hangs up, winding heats up itself and the cap.
Richard Allen
Richard Allen
If you spin the disc by hand and then apply power does the disc come up to speed more quickly?
If you spin the disc backwards and then apply power does the disc come up to speed but in reverse?
Stuart Johnson
I haven't tried to spin it by hand first. Each time it runs before tripping the fuse it is going a little faster. Once it gets enough speed it will keep running.
I haven't tried spinning it in reverse.
Stephen Mushinski
Unplug the unit and blow out the start switch. Sounds like dirt or saw dust has got in the contacts for the starting circuit. Sometimes the contacts are not closed on start up. Could also be the cap but the unit isn't very old and I would hope a cap would last longer than that. I have seen whole runs of caps bad and they died very quickly. That is why our new TV's last two years now. Bad (cheap) electronic in the power supplies.
