burial urn sizes
burial urn sizes
burial urn sizes
I can't find the info. I need to build one immediately. Can anyone tell me where the info is.
Re: burial urn sizes
Michael Mocho
Hi John,
I believe the proportion is approximately one cubic inch for every pound of body weight. Sorry for your loss.
Thanks- I found that plus the 200 inch standard. I'm now trying to figure out how you calculate that. I'm not a math person. I read somewhere that you could calculate the size using rice but I'm having trouble finding that.
Bill Jacksonville, nc
What Size Urn Do I Need?
Found this info at everlifememorials.com might be worth a look.
Hope this gets you in the ball park.
The most common dimensions for this Temporary container are approximately 8" tall x 4-1/4" deep x 6" wide. The capacity of a container with these dimensions is about 200 cubic inches give or take a couple of inches depending on the thickness of the container walls.
bill Crommett
John: What Bill says is about right. My local mortician said that a 5# coffee can would be an approximate fit-all. My urns are considerably taller, but the cubes will turn out about the same. (maybe he said 3#, but I don't buy coffee by the pound anymore )
THanks everyone
Between my searches on this site (by the way just put in Urn, not any other words when searching) and your answers above and my son's math skills we have calculated the size and found a piece of wood. Thank you Woodcentral, this is a tough time and you have helped.
Terry Scott
John I made my first Urns last year and used
this site http://www.mainelyurns.com/cremation-urn-size-calculator.html
I tested the urns by placing a plastic bag inside and filling cup by cup with sand
I was surprised at how large the vessel had to be
Lucky for me The people I made them for wanted grandma split in half as the family wanted to take half back to the Islands and keep half in NZ Because I needed 15 cups and the larger urn only came out at twelve
The hard part was having a bus load turn up at home wanting me to put grandma in the vessels .An honor but hard work as my father hadnt passed away long
I later found out that the one that went back to the islands was buried
All the best
Cheers
Jeff Myroup
1 cubic inch per pound body weight. I normally add about 10%
1 cup rice = 14 cubic inches
1 gal = 231 cubic inches
volume for sphere= (4 (pi) radius cubed)) /3
volume cylinder = (pi) r squared (height)
Volume cone = ((pi) (h) (r squared)) /3
Hope this helps
Thanks Jeff. That verifies that the size I've chosen is enough which is great because I already have the outside done and have started hollowing.
Barry
Mahoney could probably tell you.
