Air Compressor
Air Compressor
Air Compressor
dick gerard
Just blew the head gasket on a Husky (Home Depot) 30 gallon oil-less AC. Have had it 3 years and had it repaired twice before for faulty on-off switch. Prior to that I destroyed 2 Sears 30 gallon Crapsman compressors. If I add all the money for 3 compressors and 2 repair jobs, I'd have the money for a better compressor.
So here's where I need some advice. Lowe's carries the Kobalt brand 30, 60 and 80 gallon cast iron oil filled ac's. Home Depot has Husky in the same ranges.
I use it for pneumatic tools like the cut off tools, die grinders, car body saws, sanders, etc. Budget is tight so $700 is about all I can justify to SWMBO.
Questions:
1. Anyone had any experience with either of these brands of compressor?
2. Electrical ... if the specs say 240 volts, does that mean 220 won't work?
3. Anyone know of any other brands in my price range?
4. Does anyone know how to comvert this Husky 30 gallon tank into and auxulliary tank for additional capacity which would mean less cycling on and off?
Thanks in advance.
Dick Gerard
Re: Air Compressor
Leo Cuellar
Re: Air Compressor *LINK*
Leo Cuellar
Hi Dick, I don't have any experience with either of the brands you are looking at but Grizzly has a 7hp 60g Porter Cable on sale till the 31st. I've included a link for you.
Most 220/240v will run across a range of 208-240v without any ill effects, you might end up with a slight variance in actual rpm due to internal wiring differences and actual voltage supplied.
Hope that helps a little,
Leo
Compressor
Re: Air Compressor
Re: Air Compressor
Have you looked for a used one. I didn't have any trouble when I went looking for a 2 stage 220 volt compressor. I found one heck of a deal and she was supposed to hold it for me but sold it to the first guy that game along the next morning even though I got there by 10am. I found 2 more within 30 miles of the house and bought one of them. I don't have it installed yet because I need a heavier 220 line going to the shop to run the 2 new 220 pieces of gear I have purchased in the last year.
I'm with you I spent too much money fixing my 30 gallon compressor. It's been jury rigged to the point that I don't know if I can sell it once I get the new one installed.
As far as installing 2 tanks together I looked into it. It isn't hard but I don't know if it solves anything. The compressor won't cycle as often but will run a longer when it does meaning your still taxing the motor.
Re: Air Compressor
Re: Air Compressor
Bill McWhirter
I have a Kobalt 60 gal. and it's OK. Had to have it repaired once under warranty-warped head gasket. Service guy said that it was a common problem with Kobalt because it used small piston and ran them very fast which generated a lot of heat. I am thankful that I have mine outside because it makes a LOT of noise. If I had it to do over again, I would go with one of the commercial brands rather than a big box brand.
On the positive side, I called, and within a couple of days the technician came to my house and replaced the gasket and showed me how to do it. Implied I would need to do it again at some point.
Re: Air Compressor
Re: Air Compressor
Carole Valentine
I have the 30 gal Husky. The copper fill tube ruptured and had to be replaced. Actually "Mr. Fix It" Jeff Willaford was kind enough to help me replace it! Surprised it didn't start a fire, since I had accidentally left it on. Lesson learned there. I think a compressor has to withstand quite a bit, and the next one I get will not be a big box brand. There is a reason those cost less!
Re: Air Compressor
Re: Air Compressor
bill Crommett
Different jokes for different folks. I am still using a Craftsman oil compressor that I bought used in the 80 s sometime. It got to making a lot of noise so I bought a big box oil-less about five years ago, but I couldn't stand the noise so I relegated it to the barn for tire inflation and brought the old Craftsman back to the shop where it still compresses air and sounds like the piston is trying to change places with the outlet valve. But remember that years ago "Craftsman Was A Sign Of Quality".
Re: Air Compressor
Dick Hines
Re: Air Compressor
Dick Hines
I am on my third compresser since I started truning in '98. They all have been oil less ones. I ther next one , not soon I hope, will the biggest one I can get into my turck and will be a oiled one.
I moved mine into another area in the shop to cut down on the noise. That helped a lot , for now.
Re: Air Compressor
Leo Cuellar
Peak H.P. rating... *LINK*
Leo Cuellar
can be confusing, there oughta be a law against it :(
There are some reviews of this model at Tool Critic
Some additional info from another company, if I had the bucks, I'd get one.
cplc7060v
Re: Air Compressor
Re: Air Compressor
Fred Holder
I've had a Kobalt for Lowe's for four or five years now. It is the 60 gallon tank and has worked with no problems so far. We don't use it that hard, but it handles all of the air tools that we own. I don't recommend less than 60 gallon tank for using air grinders, etc.
Re: Air Compressor
Rob Wallace
Rob Wallace
Dick:
I just replaced my Crapsman oil-less air compressor (which worked fairly well, but LOUDLY, for over 15 years) with a commercial-rated, cast-iron head, oil lubricated compressor manufactured by Castair made and assembled in Minnesota, USA. My local machine supply recommended it, I saw several models they had in stock (built like a tank, not just with a tank), and after doing some additional research, I dropped the cash. The service complaints on these units were few and far between, and the guy at the store gave me names of local businesses that have been using these compressors for a long time. Calling these references convinced me that I made a good choice. I now have to try and listen to see if the compressor is running - estimated at about 1/3 as noisy as the oil-less compressor it replaced - my compressor is located in my garage with air piped into my basement shop. I actually got a 'thank-you' and smile of approval from SWMBO when she heard the new unit running for the first time. Should have made the move to belt-driven, oil lubed years ago.
I did the homework and took probably too many hours of Internet search time reading comments and various blogs, messageboard posts, and numerous ratings about different brands of compressors before making any purchasing decisions. Husky and Kobalt, in my estimation, are low to middle-of-the-road, and Campbell Hausfeld slightly better. Porter Cable, Bel Aire, Senco, Hulk, Hitachi, etc. are probably also in the same mid-to upper cohort - You can also consider significantly more costly compressors like Ingersoll-Rand, etc., but I didn't even investigate this class of compressor since it's well outside my price class (or needs, for that matter). All of the comparisons I made were are based on comments related to parts replacement, quality of various components, quirks and problems about use, pressure regulation, noise made in operation, and customer support. Some comments reflected problems associated with poor assembly (fittings not fully tightened, bent or improperly installed gaskets, etc.) or parts broken on or before delivery - Husky compressors were mentioned here, although to Home Depot's credit, they replaced the defective units immediately. If you go with Husky, Kobalt, or any "big box" vendor, be sure you have the opportunity to test the unit's function while it is in the store (may have to buy and install oil if you buy an oil-lubricated version). Any time you can try the unit before purchasing you should do so - let your eyes and ears experience what you will live with, hopefully for a long time, without problems.
Good luck with your purchase - ....."just been there and just did that!"
Rob Wallace
Castair
Re: Air Compressor
Re: Leo, That sounds like a pretty good deal,
John Veerkamp
Hp ratings for consumer motors, especially compressors are advertising fiction. You really need to look at CFM ratings at various pressures to r accurately compare compressors. Craftsman gets the rap for starting this marketing trend, but they're all guilty. Buyer beware.
Re: Air Compressor
Re: Air Compressor
John Jordan
If you have a Tractor Supply Co. ther, check them out. They sell Ingersoll-Rand, and sometimes have a good price-You should be able to get something in that price range. I used a 60 gal "so called" 5hp Campbell-Hausfield for a long time, but have a big I-R now. :)
John
Re: Air Compressor
Re: Air Compressor
Dave Peebles Lyons, Ohio
Rob,
How can you call it a Crapsman when it worked for you for over 15 years. :) I guess is should have been good to you for 20.
I too am not happy with the path they have taken in the last ten or 15 years, but I still have some good tools that they made when it was all I could afford.
I believe the reason for lower quality tools is because we insist that they sell at the lowest price. It is a bad situation to say the least. But, it is one the consumer created. But this is just mho.
Best wishes,
Dave
Re: Air Compressor
Keith Tompkins
Re: Air Compressor
Keith Tompkins
Hey Dick, I'd just change the head gasket. Not hard to do.
