Finishing the inside
karl jr
karl jr
Aha moments.
Talk about "aha!" moments. Eureka is more like it. Or, "I see, said the blind man when he picked up the saw."
I made a bunch of sanding mandrels and glued foam to them. I then attached an abrasive to that. Works a charm, let me tell you. Scrapers do quite the trick, too.
I feel like I've invented the wheel, or fire!
Can you tell that I'm feeling pretty good about my bowl endevour?
KTK
32 down and 3 to go.
Re: Finishing the inside
Carl, I take it this is the follow-up
Keith Newton----Little Rock, Arkansas
to using the spray contact to bond abrasives?
If so, I would like to hear more about what you are doing now. There may be a few more tips that you could use.
How open are the bowls that you are turning?
What power source are you using to drive these sanding tools, at what rpm?
What kind of foam, and how thick?
What diameter are the sanding disk?
karl jr
Re: Carl, I take it this is the follow-up
karl jr
Good morning, Keith.
You're right. The spray glue worked great.
The bowls average about 10 inches across the long axis (natural edge). And they're about 4 or so inches deep. I was having a devil of a time sanding the insides. I tried a right angle drill, but that didn't work so good. It was a little hard to control, and the sanding discs are way expensive.
My solution was to make some curved sanding blocks that fasten to a screw chuck. I glued thin foam (fat 1/8 inch) to the blocks. Then a glued abrasive to the foam. With the lathe spinning at about 100 rpm's or so sanding the inside was a peice of cake. Some of the sanding disks are about 3 inches in diameter and 1 1/2 inches thick (made out of a 2x4), but they didn't reach all the way around the interior very well. The most affective one was made from two layers of 2x4, and it has a much smaller diameter. That one worked very well because the sanding surface was much further away from the chuck. The extra clearance which allowed me to swing the bowl around with no risk of hitting something.
The face plate I used when reversing the bowls also has a peice of foam glued to it. The nice thing about this stuff is that it has a cloth (nylon?) face on one side. No black smudges for me to deal with. One other thing that really helped was a bowl I used to cradle the work peice. I wrapped the rim with foam, two sides opposite each other with two layers to accomodate the elliptical shape. Turned a long tenon (1/2") that fits a hole in the banjo opposite the tool rest holder. I also turned a tenon on the faceplate that fits into the bowl-holding bowl, so I can use that when working the foot and signing.
Thanks to your advice (and others) I licked that little sanding difficulty.
KTK
Still 32 down and 3 to go. Waiting for the ibuprofen to kick in and ease the pain in my aching wrists and fingers. Also gotta finish shoveling out the neighbors.
