spontaneous combustion
bill Crommett
Will Mahoney's walnut oil dry with enough oxidation to cause spontaneous combustion of the application rags ?
How is it different from ordinary walnut oil ?
Re: spontaneous combustion
Do you really want to take a chance??
I always spread out all of my cloths and wipes to dry. The LOML calls it my little "clothes line". I figure if they are dry, they can't catch on fire.
Re: Do you really want to take a chance??
bill Crommett
No, JL. I don't want to take a chance, but it is a pain to sweep off the leaves off the driveway before I throw the rags out to dry. This a special problem because Mahoney's oil is reputed to be non-drying and therefore should not oxidize and get hot. True or false ?
I'm with JL. I can never remember what oils will heat up and which ones won't so I just err on the side of caution and spread anything that has oil on it out on the middle of the concrete floor at least 2 feet from anything. That way I don't hve to worry or remember.
Jesper, Denmark
Re:My method for rag safety.......
Jesper, Denmark
Any rag with paint or oil on it get soaked with water and put in a plastic bag and tied off and thrown in the thrash.
The water interferes with any build-up of heat and stops any oxidaton reactions. It takes more energy to evaporate the water than there is available in the oil.
robo hippy
Mike's Walnut oil will cure and harden. It takes a week or so. The rags with the oil in them do not heat up or combust, even if they are soaked.
robo hippy
I set up a "clothes line". I either drape the wipes over the line or drape them over a stick. When they are dry, they get tossed.
I'm usually "finished" after I've done the finishing. So I can hang a stick just about anywhere - including the lathe.
Barry L Elder
I guess I'm just lazy! My "shop" is a 12 X 20 storage space and my lathe is near the overhead door so when I have an oily rag it gets tossed outside onto the concrete slab. The next day it goes in the dumpster. Why take a chance!
bill Crommett
Thanks all for the tips. But I still have a question : How can an oil finish harden without oxidation which will produce some heat ?
robo hippy
I would guess that the walnut oil oxidizes so slowly that there is no heat build up.
robo hippy
Bill Howatt
A very slow drying oil finish will produce heat but it will be so little that you won't notice it. A big amount of heat over a short time is the problem, not a little heat over a long time. Ultimately, the total heat given off is very, very, very, roughly, and depending on the ingredients, the same.
Bill
Steven Antonucci
I spread them flat so they dry
steven antonucci
and then use them to start a fire in my fireplace. I never have more than one rag drying in my shop.
Steve
Barou
I used to dry oil soaked rags until I discovered the dog like the flavor of some, especially boiled linseed oil. I like the idea of soaking in water, into a plastic bag and then the garbage can.
Re: I use a safety can
Steve in Durham NC
I use a safety can with a spring loaded lid. It is specificly designed to safely store this type of material. When dry, i put the rags in the trash. I do this with rags with any kind of finish as well as my disposable gloves, brushes ... This is the same method we use in our shops at the the office.
Steve
Bill Howatt
We always have a good supply of large coffee cans with plastic lids. I half fill it with water and put it inside an old metal shop-vac cannister. I removed the plastic hose inlet/outlets on the lid and covered the holes with aluminium.
Rags into the water, plastic lid snapped on and then the cannister lid put on.
When the can is full I throw it in the garbage.
Bill
