powermatic 4224 woodlathe
Jim Alguire
Does anybody else have one of these lathes? I am having a problem with mine in that it seems to get tired of being switched on & off while I check wall thickness, quality of cut etc. and just refuses to come on again. I've had this problem before and the auxillary switch had gone bad and left an open circuit, but that doesn't seem to be the problem this time.
Re: powermatic 4224 woodlathe
John Veerkamp
Try blowing out the electronic control box. My Delta does this sometimes. Blowing out the box cures the problem. Seems dust in the circuits causes some flakiness.
Lan Brady
I have never had this concern with mine.
I do blow out dust on a regular basis though.
Good Luck, Lan
JohnKyler
I have never seen this problem. But I would make sure the remote switch was clean of any dust.
If you have the remote switch that is definitely a possibility. Lots of people have had problems with those switches including me. I would also agree about blowing out the converter. I had that problem on my Nova 3000 with a converter that I installed.
Jim Alguire
Well thanks for all the suggestions. I found the problem. It didn't seem so at first, but it was the remote switch again. This is the third one I have had to replace. That is a good lathe, and I am generally quite happy with it, but they need to have a serious talk with the supplier of that switch. It dosn't come up to the standards of the rest of the machine by a long way.
Bill Turpin in WNC mountains
Get a 800T series Allen-Bradley push button switch. It will cost more but it will be the last switch you buy. They have worked for over 100K operations for me in some nasty conditions covered with mud, etc. They are industrial rated.
Jim Alguire
Thanks Bill, it never occured to me to use other than manufacturers OE. I will have a better switch as soon as our local electrical supply shop opens on Monday!
