Has anyone used the new tool support and if so how does it compare to the original support? I had nothing but trouble with the old one until I bought Robo Hippy's tape and modified the thing as he did so I could start the cut on the inside if I needed to go that way.
I like the square tube thing for running the blades through. It seems much more convenient and easy to use compared to the older T bar. Also, I think it pivots more easily.
I don't use the under support bar that keeps you from dropping the handle. Mostly because I learned without it, and it would involve an extra step. Not much of one, but still..... Also, if I do get a chip jam, I have to raise and lower the handle to wiggle it out.
Most of the time when coring I use the medium curve on the standard set of blades, and some times the large blades. When using them, I use the first McNaughton tool rest I got which has 2 gates.
I use the Mark 8 when I am using the mini or micro blades, which isn't often. I know this sounds silly, but 4 gates on top of the tool rest is just too much going on/too busy for me.
