vacuum pump
vacuum pump
vacuum pump
Starry S Chan
Other than maintenance issue such as refilling oil, what are the reasons why oil-lubricated vacuum pump is not recommended for vacuum chucking application? How can the oil or oil vapor contaminate the work?
Oil-lubricated vacuum pump is much cheaper than oil-less type and they supposedly last longer.
TIA for your tips and comments,
Starry
Re: vacuum pump
Re: vacuum pump
Ed Heuslein
I've been using my vacuum pump made from an old automotive a/c pump. The "suction" side is the vacuum and it works very well - provided you remember to check the oil a couple times a year. If you don't, your turning just could fly off as the compresson bearings fail and you lose vacuum just as you're finishing off the bottom. DAMHIKT :\ I've never had an oil problem on the turning in any respect. This does not, however, address any issues which may be present with a stand-alone oil pump like you're talking about.
Re: vacuum pump
Re: vacuum pump
Ron Warman
I have both types. One is used to pump air from an house A/C when the line is opened and uses oil. It is made to higher specs than the oilless pump and the oil is highly refined so it is pricey. The last supply was a while ago and it ran $8.00 per quart,no idea what it costs today. The other pump I have is oilless and I bought it at Surplus Center in Omaha Neb. Both will pull about 25 lbs. of vacuume but the oil type picks up moisture in the air which must be drained. If I were to buy one today I would look for the oilless type because it is easyer to maintain.
Re: vacuum pump
Re: vacuum pump
Wayne Kuhn
I assume you are referring to the pumps a refrigeration tech uses to evacuate a system.
My exp is it is difficult to contain the oil vapor. When used in my basement shop with a hose connected to the discharge and dumping to the bottom of a detergent bottle filled with wood shavings, I soon discovered this had to be vented and it soon filled my shop with oil vapor & a Funky smell.
Wayne Kuhn
Columbia, MD
