Robust comfort bowl rest workout
robo hippy
I got my new Comfort Bowl rests a month or so ago, but didn't have the time to try them out as I had other smaller things to get out of the way for a Christmas show first. There was a large Madrone log (26 inch diameter on the butt end) that would be the perfect test. I have the Oneway big bowl rests, and like them, but really love the straight rest with the drill rod on it. I had been bugging Brent about making a Comfort bowl rest for quite a while, and had to have one when it came out. Cast iron works, but feels like I am moving on 400 grit abrasive. The cold rolled and stainless steel rests are good as well, but the drill rod is a lot better.
The bowl blank was 24 by 8 inched deep as I wanted to turn as big as I could, just because. The outside Oneway rest is cut/bent to an arc from about a 19 inch diameter circle. The inside rest is about 14 inch arc, but is in more of a J shape. Both Comfort rests are on a 12 inch diameter arc. The Oneway is a bit flat for most of my standard bowls, but was good for my big Madrone bowl. The 12 inch arc is more suitable for smaller bowls, in the 12 to 14 inch range, which is most of what I turn.
When turning the inside of the bowl, the different arcs make little difference as I turn green to final thickness, and have to do it in stages, so a cut from rim to bottom won't work. With the Robust, it easily reaches about 7 1/2 inches deep, from the inside of the tool rest post. With the Oneway, I could reach about an inch deeper. Both are 12 inches long. If you point them more straight in, you can get about an inch more depth. When working on the far tip of the Robust inside rest, there wasn't even a hint of vibration in the tool rest. This has been noticeable on any other deep tool rest I have tried.
I am not sure about the inside Comfort rest being an arc of a circle as compared to the more J shape. It works fine, but I am used to the blue cast iron rest that Craft Supplies carries which is in more of a J shape. It may take some getting used to. I am not ready to retire the Oneway rests, and probably never will, unless Brent decides to make a whole range of Comfort bowl rests. I would consider the ones he has now more for medium/standard bowls. Given my own preferences, I would want about 3 or 4 different sizes, all with the drill rod.
No affiliation with Rubust other than a happy customer.
robo hippy
