Dragon Wand
charlie belden
No good deed goes unpunished.
When I delivered the Bling Wand to the little girl who patiently waited almost a year for her wand - her brother - a drummer - wanted one. So this Santa's Elf went back to Santa's Workshop and got to work.
The wand itself is oak - not the easiest wood to spindle turn. Fought me every step of the way. Left a tenon on the handle end that was long enough to go through both of the maple "rings" and into the black walnut grip. The grip has a hole in one end for the wand's tenon and a short tenon on the other end for the "cap ring". A tenoned top ball out of what is either "pink ivory" or "tulip wood" - that I think of as Bacon Wood since it has red brown streaks in a tallow color - finished off the piece. The "rings are interchangeable and gives you four possible arrangements so the kid got to pick their location and orientation.
He wanted some carving on the piece so I did "chevrons" - sawing the lines first then chiseling a bit to give them a bit of dimension. Initially I stained the low areas a dark brown to accentuate the low areas but then used a pyro pen to shade them and ended up using the shading pen to "carve" with.
Since I'd left the top of the want square - actually it was a rectangle with slightly different side lengths - where the square cross section blended into the round cross section looked to me vaguely as a lizard or dragon's forehead and snout. A little more pyro carving and burning and I was done.
In hindsight, I should have put the "dragon face" with the centerline of the nose on a corner rather than on a flat face. Maybe I'll do that on a future wand.
This one had two fun parts. The first was handing him the parts and having him decide which "ring" would go where and in what orientation. Took him close to half an hour to weigh the pros and cons of each possibility before making decision. And since he'd seen an earlier wand that I'd put Banty Rooster Tail feathers on [ from am old fashion feather dusters ; ) ] he asked for a feather on top. Small hole drilled, feather selected, trimmed and super glued in - and the second fun part happened.
First was the visual examination - and then the test of the "feel" - the gripping positions and the balance.
This is cooooool!
It's always nice to get a positive review of a piece ; )
THANKS!
That was icing on the cake.
Not the most refined piece I've done but it's one I - and maybe its new owner - will remember.
Each day we make memories - for ourselves and often others. Doesn't take much to make them good memories - as this story shows.
