A good use of Jansco lights (long)
Mike Foster
I just finished a thin walled piece tonight out of box elder. It is turned to a pretty consistent 1/16". I was reluctant to shine an incandescent light on this piece for fear that it would dry and distort the piece before I got it off the lathe. Normally this wouldn't be an issue, but the nature of the piece pretty much dictated that it be turned from both ends (sort of a hollow tube but it's not ready for prime time yet). This meant that I had to keep the piece from distorting as much as possible before flipping it to hollow the other end. The little Jansco lights put out enough light to trans-illuminate through the wood (at least box elder) and worked perfectly. Got the piece done and off the lathe.
BTW, I had turned the first of these on Sunday out of Yew. I didn't try the light on it, but it might have worked. After flipping this and getting the wood down to 1/16 of an inch, all looked good, but it needed some sanding. Well the wood was still dripping wet and there is a lot of resin in it, so it instantly clogged the sandpaper. I decided to leave it on the faceplate and waste block to sand a day later. Stupid choice. I even knew it, but watched the wood for the next two hours with no sign of cracking and thought I might get away with it. Next day, big crack up 1/2 way through the piece. Lesson learned. Not even good for firewood since there is so little wood.
Re: A good use of Jansco lights (long)
Mike I've had the same issues. Still working on them but here's what I've been playing with. I keep a spray bottle handy to keep the outside wet while turning the inside.
When I'm done and ready to sand I blow as much water out of it as I can with the air compressor.
Then I'll try flash drying it with a hair dryer. I just want to dry the surface to sand not dry the whole thing. Often the sandpaper still clogs so I use a file card to clean the sandpaper. This works really well. It's a pain to stop every 10 seconds but it does work.
When I'm finished with this or if I decide to skip the sanding I'll do one of two things. Either wrap it in a plastic sack and each day for a week or more turn the sack inside out. This really really slows down the drying. I have dried spalted dogwood limb slices this way. I would not have thought you could dry a slice of end grain with the pith without cracks but if you dry it slow enough it works. Granted dogwood is less likely to split at the pith than some woods.
The other thing I'll do is the paper bag thing. I do this on a lot of thin vessels. I'll open the bag for a few minutes each day to keep the mold down and speed up the drying a little. The bag still slows it down enough to keep the checking down. After about 2 or 3 days you don't need the bag.
Good luck with the project. I sketched one out the other day that is a sort of an offcenter tube. There is a raised portion with coves in it that will be thicker than the rest of the piece. I don't know what problems that will cause.
Terry in Ottawa
I've been fairly happy with the Ikea Jansjo light but I find that the bendable arm has gone limp. It won't stay in the position I want, but gradually succombs to gravity. Any fix (other than anti-gravity suggestions)?
Terry in Ottawa
Steve Kubien
I have found the same thing
Steve Kubien
...so I will be anxiously awaiting replies to this.
Mike Foster
I haven't had the problem yet. but I can definitely see the potential (I just got my lights a few weeks ago). I don't have an answer, perhaps stiffen it a bit with a wrap of tape?.
Mike
Rob Wallace
Rob Wallace
Terry:
I hope my Jansjo lights don't get to that stage, but I'd probably jury-rig a flexible "splint" made of No 14 or No 12 copper wire, taped to the shaft with electrical tape. Inexpensive and worth a try...??
Rob
Flex condiut stiffening
Galen Vetterick
Rob
I changed my Jet 1220 light to a longer section of flexible conduit taken from a surplus lamp. Over time it now will not hold the weight of the lamp well.
I thought maybe using heat shrink tubing over it may draw into the helix and stiffen it. I know the tubing is not thick but thought it might give the joint a little more stiffening. We used a heat shrink tape for electrical repair but need to find a source for either since I no longer have my old job as a source!
You might have a "secret souce" for heat shrink from ISU you might try on your small lamp.
