Stick Pens
Stick Pens
Stick Pens
arthur mc viccar
For the first time, I have made a bunch of stick pens, using the Papermate inserts. And after only a couple of hours use the one I gave my wife leaked. So I switched out the insert and she has not had any more trouble. But a couple that I sold have come back to me with the same problem.
Have any of you who have made stick pens experienced this problem? Any idea what is wrong?
Re: Stick Pens
Re: Stick Pens
Fred Holder
I've never used Papermate inserts. I make my stick pens using BIC Pen inserts. If you buy a box of the pens, they come out to a cost of about 10 cents per pen insert. I've never had one of them leak unless I damaged it while inserting in the new wooden pen. Have you tried the BIC inserts?
Re: Stick Pens
Re: Stick Pens
Scott Greaves in Blackfoot ID
Hi Arthur!
If I were to guess, I would say maybe you made them too airtight. Ever notice how cheap plastic pens usually have a little hole drilled in the barrel? The ink probably needs an air relief. If it is too airtight you would build up just a bit of positive pressure as you insert the refill into the barrel, maybe just enough to make it leaky.
But that's just a guess.
Scott.
Re: Stick Pens
Re: Stick Pens
Emmett Manley, Lakeland, TN
What is a stick pen? I never turn pens because I don't want to fool with all the components, but a stick pen sounds like a fun item. Do you just turn a wooden body to receive the shaft of an inexpensive ball point pen -- or just the insert of such a pen, or what?
Anyone have a photo of a stick pen?
Re: Stick Pens
Re: Stick Pens
Ed Larson
Scott is right. If you make them too air tight they can leak due to changes it temperature or if you make them at sea level and bring them to a higher altitude. I drill a small releif hole in the pen blank before turning with my smallest drill (1/16??) into the hole drilled for the pen tube.
Re: Stick Pens
Leo Cuellar
Re: Stick Pens *LINK*
Leo Cuellar
Check out this you-tube video from Capt. Eddie. Explains the whole process.
Cheers,
Leo
12� pen
Re: Stick Pens
Re: Stick Pens
Great. Thank you. I also found a detailed written account of the stick pen procedure on the internet (Kurt Herzog). Looks interesting.
