A55 Smoothing Plane
Turning long segmented pieces?
Craft Supplies USA has brass couplers. They are more appropriate for a walking stick with the 15/16" and 13/16" diameter couplers.
Brass and copper fittings are available at maybe 3/4" or so locally and copper up to 3" on-line. Brass is not cheap ($45 for a 12" piece).
So, what I was thinking is to make a mortise and tenon to connect segments and then turn down the area around the joint. I would size it for a suitable piece of brass or copper. I would then assemble the piece and glue it with the copper or brass in place. This would reinforce the joint. I figure if you lacquered or put a finish on the brass it wouldn't tarnish as fast (or you could polish it).
I figure this would be suitable for a long "torch" or for a staff or whatever.
The other choice is to get a bed extension - at $237 for a 20", that ain't gonna happen soon.
Other thoughts?
Re: Turning long segmented pieces?
Re: Turning long segmented pieces? *LINK*
Stuart Johnson
What about a nice long brass rod with a turned two hand grip. I seem to remember something along that line when I was a kid going to church. There was a candle taper on a slide on the end of the brass tube. Even better here is a link to one.
Candle lighter / snuffer
Scott Greaves in Blackfoot ID
Hi JL,
I'm not sure any metal coupling between the segments is really necessary. Most long spindles like that are not intended for a use that would apply any kind of lateral force against the joint. There may be linear force along the length of the shaft, but less likely any kind of side force. A side or lateral force would be a reason to shore up the joint with metal pieces. It would probably be jut as functional if you did wooden mortise and tenon joints and then epoxied them together. A little "design element" at the joint would even hide the joint from most people.
Scott.
OK will try a sample.
I've got a few pieces of maple as well as a LOT of 8/4 cherry.
Re: JL- I have a stash of several diameters ....
JamieDonaldson
...of allthread rods from golf course machinery, and have made splices with sections of the allthread epoxied into a tenon joint that is strong and almost invisable. The threads eliminate any movement in the drilled holes, and the epoxy remains a more flexible adhesive than most others.
Jim Barbour
jim barbour
A few years back I turned three Heraldic Staves for our Faculty Marshals to use in formal academic processions. Two are just over 6'6" tall and the other is just under 5'. All three are from oak which grew on the campus of Elon University (Elon is Oak in Hebrew so the connection to oak is pretty important). I had no bed extension at the time so I was limited to 24" segments. As was suggested previously, I too used steel threaded dowels and epoxy for the joints. I found a couple of strap wrenches to be VERY handy in getting the joints to match up grain just as they went full tight.
These staves are used several times a year and function as walking sticks, so they have more lateral stress than most items; at their length simply striking the ground in front of the walker as the staff swings forward puts quite a bit of stress on the joints. When I last saw them (opening convocation this past fall) they did not appear any different than when I delivered them three years past.
In the picture there is a joint just below the oak leaves where the staff goes from octagonal to round. With come careful placement he joints are virtually invisible.
