This is about as much use as I can get from the recycled burl table in the post below. These "chip muffins" make great fire starters. Three of these "muffins" will equal an armload of kindling and take up a LOT less space. Take a yard-sale muffin tin, some paper liners, and a block of candle wax and you can get about 200 starters. Dribble melted wax over the chips and OILA!
I use the hot plate of my Mr. Coffee to slowly melt the wax while I work at the lathe. (Has the added benefit of never getting too hot, and shuts itself off after two hours. A safety feature for an adle-headed old man such as myself) I don't add anything but the sawdust/chips and parafin, and filling them tkes only a minute.
A side benfit is that the missus can successfully build a fire in the fireplace with these every time. A single match touched to the paper cup liner will produce a flame about a foot high and burn hot for about twenty minutes.
I am wondering now if I can use the ash as a soil ammendment (or something)
I had no idea that making wax and shavings cakes was so popular! One of the by-products of all the wax supported turning I've been making is a messy mix of wax and wood shavings. Depending on the structure, the ratio of wood to wax varies significantly. If there is a lot of wax with a little wood, I'll melt it all down again and reclaim the wax. The problem is when the ratio goes the other way - too much wood and not enough wax - if you try to melt and reclaim the wax without using some kind of press you just end up with cake! way more work than it's worth.
I have burned a few of these cakes just for fun - they burn like a slow torch for a long time. I've been reluctant to use one in the fireplace. At present I have two grocery bags full of mixed wax and wood. Perhaps I should go into production!
It took a 13 year old Boy Scout in my Troop to show me, but one of the best firestarters is a Pringle "potato chip". Try it. Light one, a three inch flame will burn for several minutes. I no longer eat these after seeing that, however.
