Help! - long
Help! - long
Help! - long
Tony - Memphis
Let me begin by saying that I am not a turner! 95% of what I have turned has been spindle work for furniture, and I'm not that good with that. Snyway, I had an old copy of Wood magazine that I noticed a neat little turnign project. Hmm, I thought, that would make a nice Christmas present for the folks (they are hard to buy for these days as they have everything). This thing is basically a shallow bowl on a footed spindle. I can't recall the issue date. I quit subscribing many years ago, so it is fairly old. Anyway, I've never turned a bow before. I have some books and videos and such that I looked at first. The outside went ok. No major issues. The inside, however, went terribly! I must be doing something fundamentally wrong, though I've checked the books and videos and it appears I'm not too far off. This is a piece of ~6" diameter cherry. I am using a Jet midi lathe. The article showed attaching with the screw thing. I wondered if my attachment wasn't solid and that was causing problems. No issues on the outside thought. But, I took it off the screw and gripped it in the jaws (now I have to figure out how to remove the area I am gripping). That may have helped some, but it was still ugly. Thsi shape has some pretty steep sides. My tool is fresh and sharp (I'm using a Sorby 3/8" bowl gouge with close to factory grind). I also tried a scraper. That just tore it and vibrated liek crazy. I got very frustrated! I got it fairly smooth with no realy bad tearout, but, obviously, I was donig something (or multiple things) wrong. I have another blank ready. I'd really like to have better luck with it! Another issue I had was getting the screw thing into the blank nice and square. I drilled the hole on the drill press, but I never could get the screw in real square. Thanks for any help or guidance you can offer. I meant to take pictures so you could see the setup, but I didn't get a chance. May do that tonight.
Thanks!
Tony
Re: Help! - long
Re: Help! - long
robo hippy
Best advice I could give you is to find the local club and ask for help. Next to that, get (buy, borrow, or rent) some bowl turning DVD's (again, the local club would be good for that. After that, there are a lot of turning videos on You Tube.
Turning the outside of the bowl is fairly simple. The inside is more difficult as you can't see into it as well, and the inside curve makes going from the rim through the transition more difficult.
Steeper sides, with a steep/sharp transition is more difficult than a shallow curve.
robo hippy
Re: Help! - long
Re: Help! - long *LINK*
Tony There are a lot of turners in the Memphis area. Hands on help will be so much better than anything we can write. Check the link below to see if you can contact someone.
If your using the screw that comes with the chuck are you using the jaws with it? On my chucks the screw pulls the wood down against the jaws. If it isn't quite true the last 1/4 turn or so will force it flat against the jaws. If your blank isn't sitting against the jaws you will definitely get some chatter.
When you grip the tenon on the bottom there should be a shoulder so the wood will sit on the top of the jaws as well as inside. This keeps the bowl from rocking and causing chatter.
Is the bowl side grain or end grain. If the grain runs parallel to the bed then it is end grain. On end grain bowls you should be cutting from the center out to the rim in order to cut downhill with the grain.
If the grain runs perpendicular to the bed of the lathe then you should be cutting from the rim to the middle to cut down hill with the grain.
http://www.midsouthwoodturners.com/Home.html
Re: Help! - long
Re: compote
Tony I remember that. It was just a few issues ago I think. The plate should be side grain and the spindle of course is long grain.
Re: Help! - long
Re: Help! - long
Fred Holder
Hello Tony,
That is a pretty complex piece for a beginning turner. I just sent you a copy of the article on turning bowls that I wrote for the January 2011 issue of More Woodturning. I hope it will help. That is a fairly shallow bowl that you are trying to turn for the piece, but your bowl gouge, if you have one, should have close to a 60 degree nose angle to be able to cut from the rim down through the bottom. The bowl as John Lucas said should have grain perpendicular to the angle of rotation and the stem and base should have the grain parallel to the axis of rotation. The two pieces of wood will require different tools and turning processes.
Is your chuck a four jaw woodturning scroll chuck? If not, I recommend that you glue the turning blank for the bowl to a waste block and screw a faceplate to the waste block. This will give you good solid mounting for both the outside and inside. Good luck, that should make a nice Christmas Gift.
Re: Help! - long
Thanks!
Tony - Memphis
Now you tell me! Well, that makes me feel a little better though. I got a good base turned using a screw plate (I turned through my screw holes on the first one - no metal, just air thank goodness!). The spindle part I can handle. But yeah, the bowl has given me fits. I got something hacked out, but it just wasn't pretty getting there and ther is more tearout than I would prefer. Thanks for the help everybody. I'm going to see if I can salvage the current attempt and try to do better on the second. I made two sets of blanks knowing this wouldn't be a breeze. I'm not much on wood magazine in general, but my turning level is suited by their articles and I like this little shape. I think the form is pretty nice. Thanks much for the help and the article. I think I'll try the waste block approach. I know that is good and solid and flat. Oh, I have a Nova midi chuck I think it is. Nice piece.
I may try some pepper grinders for gift if time permits. Those ought to be a breeze compared to this! I've turned a few spindles before. Stuill not good, but much mor comfortable in that mode. May make some whistles too. The kids love those and it annoys the parents I give them too (big grin).
Tony
Re: Help! - long
Re: Help! - long
Peter Lamb
Another possibility go to You Tube and search "bobham5". His has posted many multi- segment wideos on most objects that can be turned on a lathe. His too lselection and his use of them is excellant!
They should be very helpful to you in the mean time.
Re: Help! - long
Re: Help! - long
Terry Scott
Tony have a look at our club web site www.sawg.org.nz and there are some great step by step articles
May I Ask if you were turning the bowl end grain or cross grain.Bowls are differnt to spindle work
Using a screw chuck drill the hole and then secure the screw in the jaws then wind the wood on .This will seat the wood against the jaws
Scrapers dont work to good when turning cross grain so
Using a 55 degree grind also makes it easier to keep the bevel rubbing on the inside
I am no expert but you are more than welcome to email me and ill see if I can help or point you in a direction of someone that can
Cheers
Re: Help! - long
Re: Help! - long
Tony - Memphis
Thanks. Nice site. Lots of good info. The bowl part is a regular cross grain situation. I read somewhere yesterday that the scraper doesn't do well up the sides of the bowl. Or maybe that was in a video? I've done so much reading and lokoing now that I'm confused!
Tony
Re: Help! - long
Thanks!
Tony - Memphis
I'll take a look at those.
Tony
Re: Help! - long
Re: Help! - long
Bob Macgregor
You're in luck. The Memphis Public Libary has several woodturning books, including Raffan's book (Turning Wood) AND several woodturning videos as well. Best of all, the price is right!
BOB
