Lighting??
Lighting??
Lighting??
Thomas Norton
As I move to re-setting up my lathe I was wondering about lighting. What would you all reccommend?
Thanks!
Re: Lighting??
Rob Wallace
Re: Lighting??
Rob Wallace
Thomas:
I suggest you approach the topic of lighting from three levels:
1. Ambient shop lighting
2. Concentrated task lighting
3. Specialty lighting
AMBIENT SHOP LIGHTING is usually accomplished with fluorescent lights - I prefer 5000K color temperature; others may want warmer color balance. There are a number of web sites out there that can help determine optimal spacing for specific fixtures and wattage ratings to provide general illumination of the shop/studio.
CONCENTRATED TASK LIGHTING includes any specific lighting at or near the operator's position at the lathe, grinder, carving station, etc. that provides additional (and often adjustable) more intense light that assists in accomplishing whatever job is needed. I use a combination of track lighting above my lathe and grinder areas, which are fitted with several floods or spotlights to produce even (no shadows) and fairly bright lighting of the area. In addition, many (most?) turners also have at least one adjustable lamp which focuses its concentrated output right on the object being turned. The flex-necked Moffatt Lights are a popular solution for this form of lighting. Other turners have used a variety of adjustable lighting options to accomplish the same task - providing intense light at the actual location of the work in progress - just like a hospital operating room. Some have even put used dental lights into service for this task.
SPECIALTY LIGHTING might include units that assist in illuminating tasks (like hollowing) that need additional adjustment or operation-specific mounting that the other two forms of lighting can't readily accomplish. Recently popular LED lights (battery operated or the plug-in LED work lamps from IKEA) can be used to assist in seeing how hollowing operations are proceeding. Other specialty lighting includes 'internal illumination light' like those used by Johannes Michelson for making hats, or Binh Pho for turning thin-walled vessels, to judge wall thickness. I have a fiber-optic light source and long, flexible light tube that I use for lighting vessels for inspection or wall thickness determination. I also have seen turners use head-mounted lamps to accomplish some of these same specialty lighting tasks.
I think you will find that your lighting needs will continue to change and adapt with the kinds of turning you do. And most folks will also find as the turner ages (along with their eyes), the amount of additional lighting s/he needs will increase; increasing age requires brighter lighting.
Hope this helps,
Rob Wallace
Re: Lighting??
Re: Lighting??
As cold as my shop is I may go back to my 300 quartz lights. That might heat me up.
Re: Lighting??
Re: Lighting??
What Rob said.
I have fluorescent fixtures for my over all shop lighting. I have several fixtures lighting my shop.
I have track lights which use compact fluorescent PAR lamps above my lathe. The three lights on the track are approximately above my head. They light up the entire bed of the lathe (and are all adjustable and can be positioned on the track).
I have two magnet based fixtures with incandescent bulbs. I can attach these to my lathe if I need a little more light on the subject.
Re: Lighting??
Re: Lighting??
Matt Overton
I just moved my lathe and picked up a used articulating dental light on a six foot track on craigslist on a tip from here at WC. The best addition to my shop in years! I can now position the light anywhere anytime effortlessly.
