dust masks
dust masks
dust masks
bq in vt
Hey-
what do people use for dust masks? My turning area is very small and I use a dust collector and wear a paper mask, but that is not good enough. I don't have several hundred dollars for a powered helmet. I am planning at one point to get a filtration system, like the one made by jet to help out. I was looking at a powered respirator that can be found in Rocker and in Woodcraft. I think they are the same unit. It runs on 4AA batteries and provides a positive air flow. Has anybody used this unit? For about $70 it looks like it might be the solution.
Thank you.
BQ
Re: dust masks
Re: dust masks
Bill Youngblood
Speaking of Hey, I handle a lot of hay and sawdust in a horse barn plus I do a lot of turning. I use 2 masks (one in the barn and one in the shop) that are similar to the paper ones, but are cloth that can be washed. Very effective, easy on and off and not too pricey. About $40 at Rockler. Hope this helps. :)
Re: dust masks
Re: dust masks
Barbara Gill
I have used a North 7700 series mask in the sawmill and shop for years. I use the low profile dust filters in the shop. If you do a search you will probably find several threads with the details. 3-M also makes a similar mask. It is light weight, fits under a face shield and according to the specs filters the dust as well as the high priced battery operated units.
Re: dust masks
Re: dust masks
Barry L Elder
I use the 3M 6000 series masks that Barbara mentioned above. Good fit, no complaints.
Re: dust masks
Re: dust masks
Scott Crumpton
Another vote for the 3m 6000 or 7000 series. The 7000's are more comfortable. However, I found that the design of the exhaust port on the 7000 resulted in condensation drips when working in the cold. The soft pink P100 filters are nice as they won't scratch up your face shield. I keep an extra mask or two in each size for visitors and simply remove the filters and wash the mask after each use.
Re: dust masks
Ditto
Carole Valentine
Re: dust masks
Mike Mills
Re: dust masks
Mike Mills
I use the 3M Mask #8293. Filters down to 0.3 at 100%. If my prior research was correct the Trend Line also filters down to 0.3 but at 98%. These 3M filters are about 7 bucks but they are good for 160 hours. There are some washable filters the AAW brought up several months ago for about 40 bucks but again, they filtered down to 3 microns, not 0.3 and they did not give an efficiency that I remember.
Lot of different real numbers and cost to consider when comparing.
Re: dust masks
Resp O Rator *LINK*
Joe Pack
I have a beard, making masks fairly ineffective for me. I came across this product, bought one, and have never looked back. No fogging of glasses, no humid rebreathing, no looking for the mask... Even if I got rid of my beard, the Resp O Rator would still be my "mask" of choice. Always there, comfortable and extremely effective.
The fellow in the video is the inventor, and a VERY nice guy!
One last thing - I skip the little nose thingy and just learn to breathe only through my mouth.
Resp O Rator Demo
Re: dust masks
Available at most woodworking supplies
Joe Pack
Re: dust masks
Re: dust masks
Bob Edwards
I have had the best result with the TOTOBOBO mask. Vince Welch handles it and it's on his web site at http://www.vinceswoodnwonders.com/Respiratory%20Mask.htm It is lite, makes a good seal and has the best filtration numbers on the market. You can find a data sheet at totobobo.com
Re: dust masks
Re: dust masks - DIY powered
Steve Harder
I have a DIY powered respirator - a normal faceshield, ripstop nylon shroud taped to faceshield, small bathroom squirrelcage fan 25ft away, fan connected to flex plastic hose (sump pump) which runs up my back and over top of head. Nice flow of clean pressurized air.
Now I almost look forward to sanding - and I usually wear it any time I'm doing finish turning that is kicking off a lot of fines.
I have a beard and found most dust masks were not sealing well - and my eyes were always bugging me - this solves both problems.
And then normal dust collection keeps shop clean.
Re: dust masks
Any photos you can show?
Jack Savona
Re: dust masks
Re: Any photos you can show?
Steve Harder
No photos - just cut some ripstop nylon to sort of a head shape - duck tape all around a normal plastic faceshield - you just want enuf fabric to touch down on your shoulders - sure doesn't look fancy, wife kids me - but I don't wake up with scratchy eyes the day after a sanding session.
Re: dust masks
Re: dust masks *LINK*
Jack Savona
BQ, the real question is: How good is the filter? How much microscopic dust will it keep from your lungs? I bought that same filter on closeout at my local Rockler 3 years ago for $5. Could never verify how good the filtration was, so I shelved it. Kinda like the Dust-bee-gone. No filtration rating or a poor one.
Just ordered a pack of ten of these from Walmart for $12.99 + 1.99 for shipping (cheaper than @ Woodcraft & Rockler). It's larger shape looks like it might solve the problem with my beard. Plus, it's exit valve might mean I can wear it under a faceshield. I'll let you know how its NIOSH n95 filter works.
Dust mask
