Better for you perhaps, but...
steven antonucci
Without getting into a heated argument, I would like to bring two very simple FACTS to light: (feel free to independently validate via Wikipedia or elsewhere)
1.) Carbide does not get as sharp as HSS. It's a molecular thing, but generally speaking, a properly sharpened and honed gouge will outperform a carbide cutter for finishing cuts because it is sharper.
2.) While it is true that carbide WEARS longer, it is continually degrading in performance, the HSS edge can be perpetually renewed to optimal performance.
3.) All of the reading I have ever seen about carbide tools recommends using about 1/2 of the cutter while roughing out. I think they are roughly 3/4", so that means you are able to make a 3/8" pass. I can use a 5/8" bowl gouge with a ground back wing in shear to make passes that are 1"+ wide and clean across the end grain. If I had a bigger motor on my lathe, I could make a wide pass, but it stalls the belt if I try it now (so it's not the gouge or me).
I am glad that there are folks out there trying to make turning easier for the masses, but it's an aggregious overstatement to say that it is better or faster than conventional gouges.
YMMV.
Steve
