Sanding in Tight Places *LINK*
Jennifer Indy.USA
Hey all,
For those of you that sand in tight places and have been looking for a way to speed things up I was introduced to a great mini power sanding method not long ago. I assisted J Paul Fennell's class this summer at Marc Adam's School and he had tons of great tips on everything related to making beautiful pieces of turned wood. One of the many things that I took away from the class was his easy way to sand fast in tight places. it was so simple that it was one of those things that you knock your head and wonder why you never thought of it. All he uses is a small mandrel like the ones you use for a Dremel tool cut off disc, with a circle of sandpaper that has double sided tape stuck to it. Press the disc to the mandrel and you've got a mini power sanding disc. He was using his in an NSK air turbine handpiece, I haven't taken that plunge yet so I'm using mine in a small WeCheer handpiece with a mini keyless style chuck. It's a great little handpiece because you don't have to change collets. So before the end of class I bought JPaul's mandrels and also his mini drum sander to hold in this handpiece. I also got a bag of assorted sized discs. I can't beleive how easy and great these work. I've done the do it yourself thing making mandrels out of turned pieces of wood and then using rubber cement, and the double sided 3M sticky foamy tape stuff and all sorts of other gluey sticky unsuccessful ways. J Paul also showed us how easy it was to make our own discs. You just take double sided tape (the cheep stuff works best) you tape it to the sand paper then you use metal punches to punch out the discs. You can get these in a variety of sizes from McMaster-Carr supplies. Use one of those mats for cutting stuff on that doesn't damage the cutter and punch away. I got my mat at Michael's in the scrapbooking isle. If you're not up for this you can buy the discs and mandrels and mini drum doo-dad from J Paul at www.bursforcarving.com
I've included some pictures of all this stuff on my bench so you can get a better idea of what I'm talking about. Just wanted to share something J Paul shared with us in class.
Jen
http://bursforcarving.com/
J Paul's Tool Site
Re: Sanding in Tight Places *LINK*
Katherine Kowalski
Katherine Kowalski
Hi Jennifer,
Thanks for all the tips! Good stuff there. A question about the circles of sandpaper -- how does he stick them to the mandrel? Do you put the mandrel screw through the circles, or use a particular backing material to stick the sandpaper over the top of the screw head?
Thanks!
Katherine
john lopez
great info & products
thanks for sharing .
double sided tape
Jennifer Indy.USA
Katherine,
The discs have double sided tape on them. You just stick them to the mandrel. The mandrels come with a threaded screw that you remove and discard (or save them for something else) and then you stick the disc on the flat of the mandrel. It seems like it wouldn't be enough surface area for the disc to stick but they stick great and with the over hang of the disc they conform to the shape of whatever you're sanding.
In the one picture you can see at the top of the picture the portion of the sheet of sandpaper that I stuck the 2" wide double sided tape to and then punched out the discs.
Jen
Carole Valentine
Been making my own similar to this for some time. I use the head of cut off nails which fit the various collets on my rotary tool. Use the 1/16 sticky foam attached to the sandpaper then just punch out the disks. Peel the paper off the other side of the foam, stick the disk on the nail head and go. I have some that are really tiny. Works like a charm.
Jen I'm interested in the tubular one in the bottom photo sitting next to the homemade one. I use lots of drum sanders. I find them better than discs for a lot of what I carve. I've picked up some small ones over the years but that looks even smaller.
J. Paul Fennell
Jen,
Thanks for a glowing testimonial. The only things I might add are these:
The double sided tape is double-sided masking tape, which has a paper liner between the adhesive and not foam. The reason for this is because the disc heats up when in use (because of the friction generated when the disc is flexing), and any plastic based liner will melt and distort. You can get d/s masking tape in a number of places: golf pro shops use it to attach the grips to the clubs, ebay, and companies like Uline.
Secondly, I used it in the class with a low speed handpiece like the NSK Z500 (not the air-driven Presto), but they work very well in Dremels and such. I use them at about 10,000 rpm.
Lastly, small scraps of unused sandpaper will keep you in business for a long time.
Donna Banfield
Thanks for those tips, Jen.
You have no idea how much I appreciate this! Just spent the last 5 days trying to hand-sand some very tight places. Now I know how to speed up the next one.
Carole Valentine
Oddly enough, I have not had any problem with the sticky foam backing melting or distorting in any way, which surprised me. Maybe it is because the disk is so small, or because I use such a light touch with it. When I am sanding details, that little bit of cushion under the abrasive seems to work better for me. I have a couple of mandrels that I have turned from wood that are about 1/2" that I use velcro on. Can't go much smaller with that because there are not enough hooks and loops to hold. Amazing to me how "where there is a will there is a way" comes into play when doing stuff like this. I have even cut specific contours from pieces of a firm, high density foam I found in some packaging and stuck sandpaper to it. Then there is my Electro-File...could not live without that rascal now. I use old jig saw blades ground to shape as little sanding paddles.
That hits the nail on the head
Mike Foster
I've been working on a carved piece and have been struggling with sanding in some very tight spaces. In my other life I am a dentist and I have a lot of little sandpaper discs that have an attachment snap on center, so a little bit of the mandrel sticks out of the disc and prevents getting in tight if you can't angle it just so. Like you said, this is so easy I can't believe I didn't think of it. I'll be out there tonight armed with the new idea. I'll have to get a set of punches to make it easier. Thanks for posting this Jennifer, it's gonna make my day.
Mike
Jennifer Indy.USA
John,
That is cylinder with a slot in it so you just cut a square of sandpaper and roll it up and slip both ends into the slot and you have a mini drum sander that you can hold in any rotary tool. I got this from J Paul too.
Jen
Yea I have one of those. I don't remember where I bought it.
