Var Speed on a Delta Midi Lathe?
Andy Lincoln,in Dearborn MI
Hi All,
I have a Delta Midi lathe LA200.Is there any reason that I could not use a dimmer switch or a router speed control switch to make my lathe variable speed?
I have seen a finishing technique that involves a few speed changes that I would believe to be cumbersome and time consuming just to finish a pen, by changing the belt/pulley arrangement.
i also have seen that PSI sells a replacement motor/switch kit that will turn a lathe into VS.It is $100 plus shipping and I was looking for an alternative.
Remember I am not an electrical wizard ,but can follow instructions.
Thanks,
Andy
