Natural Edge? Why Not Resin Nodules?
charlie belden
Amber has been prized for centuries if not millenium. If you ever make it to Prague you'll see more amber than you could've imagined - made into things you probably couldn't imagine. When cut and polished or carved it's a beautiful material - a gem - that's not formed by heat and pressure - but by a TREE.
So I'm looking at an old apricot tree, pruned back each year for 30+ years to keep it a manageable size, and I notice that there are resin nodules scattered about on the trunk and branches. The nodules range from almost spherical to hemispheres, their surfaces smooth or crazed or covered in smaller nodules. The color goes from a pale yellow orange to a dark red brown. Some are dried and hard, some more sticky and gelatinous. Some are clusters of smaller nodules. Most are quite interesting and some even beautiful.
We exploit the qualities of the wood we turn, including knots, cracks, bark inclusions and even the bark. For some reason, the sap/resin, the life's blood of the tree, is overlooked.
Unlike knots, bark inclusions and bark, these resin/sap nodules can be removed from the tree once dry - and put back on things - like a bowl, or hollow form. Heat the underside of a nodule and the material becomes somewhat pliable - and adhesive. They can be stuck almost anywhere on a turning - and they'll stay there - I think. With some careful selection - and some sensitive use - I think they could add an additinal visual effect to some pieces and bring another element of Tree-ness to a piece.
Has anyone tried adding sap/resin nodules to a piece - and if so - were there any problems?
Re: Natural Edge? Why Not Resin Nodules?
john lopez
I once turned a small endgrain bowl from a piece of very resiny Canary Island Pine.
It was a sentimental piece for a friend who planted the tree as a kid and many years later had to remove it.
The rest of the sound wood had rotted to the point of not being lathe worthy
so the piece with resin running through it was only part sound enough to spin.
It sanded out easily (lots of clogged grit) and took a nice finish of wipe on poly.
It was an interesting effect and made me wonder about the potential of
turning more and inlay. I just haven't come across more material like that yet.
Interesting question Charlie.
