#3 morse taper question
It kind of got lost below so I'm going to ask it here. What are the advantages of the #3 morse taper.
Strength? Never had a problem with my #2. I haven't turned anything larger than 20"x6" or 12"x 15" vessel so I guess if you go really large it could be an issue. Of course you could just make the tailstock quill thicker which would probably absorb much of the vibration.
You could bore a larger hole through a turning but no one makes a tailcenter that will allow you to drill through it. In fact a lot of the more unusual tailcenter accessories fit a #2 and would require that adaptor. Then there is always the question of being able to get it out of the adaptor. In metal lathes everthing has a tang that you can force the taper tool against to remove the accesory from the morse taper adaptor. That isn't true with wood turning since they didn't design them for that. There are some things that I use (like my lamp auger boring center) that doesn't have a tang and would get solidly stuck in an adaptor.
I can't think of any other reason to have it. If you have more than one lathe then you have to stock both #3 and #2 accessories if you don't want to constantly be using the adaptor.
Re: #3 morse taper question
Don Evans
John
Regarding the Oneway 2436, it DOES have a self eject on the tailstock quill, so you can use MT3 with the tang or without, it will eject both of them.
Yes, according to Oneway the MT3 is for added strength.
When I got my 2436 I already had a Oneway livecenter in MT2 plus an addapter for 2 to 3 MT but I still purchased another Oneway livecenter and drill chuck both in MT3. Reason is the length of protrusion with adapt, the whole assembly stuck out 10" from the quill and that adds a lot of torque to the end of the livecenter wearing out the bearing etc that much quicker.
Like most things adapts are great when that is the only way you have to get it done but better without them. I don't recommend them but I'll use one if I have no other chose.
Don
Bill Howatt
My General's tailstock is MT2. I was drilling a hole with a 1-3/4" Forstner bit and the drill chuck's MT wanted to turn in the tailstock. I wondered at the time if a MT3 wouldn't be better because of the larger surface area contact.
Bill
bill Crommett
That sounds more like a bad MT #2 on the drill bit.
Don Sorry I wasn't talking about the morse taper for ejecting from the quill. I was talking about getting #2 morse taper accessories out of a #2 to #3 adaptor. If they aren't long enough to extend to the removal slot then there isn't any way to get them out.
Possibly- had not thought of that
Rob Wallace
Rob Wallace
I agree with Bill C. - the MT2 taper should be perfectly capable of drilling wood with a Forster bit. It likely is a damaged or dirty taper union (either on the male or female part, or both). Inspect both carefully for scratches, burs, or debris, clean thoroughly, and re-try the drilling. The polyurethane female taper cleaners work OK, but are ineffective against scratches that leave raised surfaces. There are relatively low-cost Morse taper reamers available (e.g. from Enco or MSC) that are useful for smoothing out bumps caused by scratches, if necessary. (Been there, done that!)
Rob Wallace
I'll have a closer look - thanks!
Bill Howatt
Don Evans
Ok, I miss understood that, but there is also on MT's a length involved with the spec's on them. If it doesn't reach the slot for using a drill drift to separate the two parts I would say the maker didn't follow all the spec's. Very possible that could happen.
Don
