3520B electric problem
Aage Rendalen
I disconnected my hard-wired 3520B in order to install ceiling boards. When I reconnected (with the addition of an extra piece of wire for reach) I tripped the fuse that controls my workshop (which has a 100 amp panel of its own). I double-checked my wire cap connections and re-tightened everything. The circuit now is fine but no power apparently reaches the lathe.
Did I blow a fuse in the electronics unit of the lathe? Any suggestions?
And PS: I'm really appreciative of the responses you provide to my various questions, whether it's sawmills that export or color retention in box elder. You make my life easier.
