Support for Lathe
Support for Lathe
Support for Lathe
Keith Inscho
While turning my first bowl on my new lathe, I discovered that if the work piece is even slightly off balance, I get a wobble from the lathe. I can make it go away by varying the speed some, so have come to the conclusion that the floor just isn't enough to hold the machine. I have it set up on normal frame construction (crawl space) with 2x10 joists on 16" centers, 3/4" T&G subfloor with 1/2" ply on top of that. Any suggestions on the best way to beef up the floor?
Re: Support for Lathe
You have several possibilities, such.....
JamieDonaldson
... as joist jacks below the floor, but that requires a concrete pad for the jack base. A steel plate larger than the lathe can sometimes be found at a metal scrap yard, or a 4'x8'sheet of 1"plywood under the lathe will spread the load to several joists and stabilize enough to work moderately out of balance turning blanks.
It may not be your floor. If your lathe is light or if you don't have the weight distributed equally between all 4 legs it can still vibrate. I have Powermatic 3520 with #300lbs of gravel on it. Total weight 1000lbs and it sits on concrete. It will vibrate if I don't have the leveling legs set properly. I might be turning out of balance pieces faster than you do but my point is even big lathes will vibrate if not set up correctly.
Start by leveling your lathe front to back and left to right. That should help. Then if you can add some extra weight it might improve things.
If all else fails changing the lathe speeds is what we all do.
Bill Turpin in WNC mountains
Use an "H" shaped frame of timbers to spread the weight to more joists. Bore holes for lathe feet with forstner bit to keep lathe from walking off the timbers. Make sure holes are equal depth. If you are happy with lathe height, use 2" x 4"s and drill mostly thru the boards to have a minimum height change. Attach the "H"'s cross bar with a half-lap joint with the crossbar on the bottom. This will transfer some of the weight to the entire length. All the other ideas are good also. My PM3520B is on its legs jacked up on 6" x 6" because I am a tall guy. If you have room, extend the legs of the "H" beyond the back to get more weight spread.
Walt Bennett
Walt Bennett
John's right. I can make my 700+ lb Stubby walk across my garage floor easily with out of balance pieces. I use ground down fender washers to shim legs as needed since the floor isn't perfectly flat and things change with just an inch or two of position movement.
Thanks to All!
Keith Inscho
Thanks to all for advice and tips! My problem ended up being two fold. The lathe was off level a tad, and the floor joists ended up being 2x8s, so the floor was kind of bouncy and just amplified any vibration. I ended up using an H shaped beam and floor jacks to take out the bounce and trued the lathe bed. Seems to have solved most of the problems. Thanks, Keith
Excellent,  I love a happy ending
Dave Peebles Lyons, Ohio
